Author Topic: vagcom???????????????????????????????  (Read 1270 times)
Offline grahamw1604
« on: 19 September 2010, 12:43 »
I currently have another post on here regarding to my golf gti mk3 problems, someone mentioned have i got vagcom??
I have looked on ebay and seen these vagcoms and just wonder how it works
do you have to use your laptop becuase the ones i have seen pictured have a lead with the 16 pin end and what looks like a usb at the other end along with a cd.?   also with mine been a 1995 mk3 does this mean mine is OBD II
any help with this would be great cos i will buy one if it will make my diagnosis easier and plus i have a mk3 vr6 on drive with faults so i could do the same with that
cheers.............
Offline snifferdog
Re: vagcom???????????????????????????????
« Reply #1 on: 19 September 2010, 13:48 »
Yeah, it plugs into a socket by the ashtray and the cd will be to install the software onto a laptop. I think the way to tell if its obd 1 or 2 is by counting the number of pins?! Someone else will probably be able to help more than me! :laugh:
Offline thebassman
« Reply #2 on: 19 September 2010, 13:52 »
Obd1 is 12 pin, obd2 is 16 pin.
Thebassman
Offline dom
  • Back in a Mk4
« Reply #3 on: 19 September 2010, 13:54 »
This thread will show you where the port is:
http://www.golfgtiforum.co.uk/index.php?topic=66384.0
If it is next to the ash tray then it is OBD2, I think they changed in 95 so it could be either.
You'll need the lead from eBay and the software, the software is available as a free download from ross-tech but you'll need to find a crack to use all the features.
Offline grahamw1604
« Reply #4 on: 19 September 2010, 16:59 »
ok thanks for all the help, mine is by the ashtray, would the vagcom be able to find faults like on the coil etc..
Offline dom
  • Back in a Mk4
« Reply #5 on: 19 September 2010, 17:27 »
Should do :afro:
Offline Deano2711
  • 1992 VR6
« Reply #6 on: 19 September 2010, 18:58 »
My 1995 model is OBD2....not sure if a faulty coil pack will flag up on Vag Com but it would tell you if miss fire is from 1,2,3 or 4 then you can check the plug and lead first then the coil pack unless you can get hold of a second hand coil pack to test it. Whereabouts are you as plenty of people on here have Vag Com and may scan it for you.
Offline grahamw1604
« Reply #7 on: 19 September 2010, 19:56 »
i am in yeovil somerset if anyone is local it would be a great help
