Author Topic: INFO Is my car Obd1 or Obd2 (with plug location pictures) with fault code link  (Read 32478 times)
Offline salsamk3gti
Hi i was wondering if anyone knows where the diagnostic plug is on the car?
« Last Edit: 18 October 2009, 12:26 by boneybradley »
Offline leegt5
Re: diagnostics plug on N plate 2.0 8v colour concept
« Reply #1 on: 13 September 2007, 19:19 »
kells
Re: Where to find diagnostics plug on Mark 3 Golf
« Reply #2 on: 04 November 2007, 19:01 »
the earlier ones are located behind the dash blanks next to (to the right of) the rear heated window switch, if you look at the pic of the dash above that someone has posted, where it shows u the location for the newer port, where the red and yellow alarm LED's are, the ports are located behind each of these 2 blanks (1 port behind each blank)
Offline boneybradley
  • Back in a Mk3...
Re: Diagnostic plug location Mk3 Obd1 & Obd2
« Reply #3 on: 07 April 2009, 09:41 »
and a link for the VR6 (you dont even need to find the plug to tell if it's obd1 or 2) http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?106705
  • Back in a Mk3...
and if you get a code check the guide here for further info http://www.golfgtiforum.co.uk/index.php?topic=35118.0  :wink:
