Author Topic: creamy film in noil filler  (Read 1870 times)
Offline mustang
  • 2Litre 8v Gti
« on: 23 January 2005, 19:25 »
Ive had the car checked out and it runs fine but ive got a creamy film in my oil filler and on the dipstick,the garage i took it to flushed the engine through but the problem keeps returning ,its not smoking when its starts up or when its warm any ideas as to what s causing the problem or how to rectify it would be helpful .
Mick Mk3 Gti 8v,standard but not for long
Offline audiquattro
Re: creamy film in noil filler
« Reply #1 on: 23 January 2005, 21:30 »
How often do you use the car? and what oil are you using?
Offline mustang
  • 2Litre 8v Gti
« Reply #2 on: 23 January 2005, 21:50 »
I use the car everyday to work and back which isnt far as for the oil not sure the garage flushed the system through and then put new oil in so not sure what oil they used.
Offline Agreeable Slick
  • Unit
« Reply #3 on: 23 January 2005, 22:13 »
on the dipstick of there are beads of water on it, or in the coolant expansion tank if there is a mayonaise type residue, then the head has gone and needs replacing.
Offline mustang
  • 2Litre 8v Gti
« Reply #4 on: 23 January 2005, 22:21 »
i havnt found any film in the expansion tank just in the oil filler area and the car drives fine i was told that it is a common problem as condensation builds up in the engine,the car is still under warranty so i think i will be taking it back again.
Offline audiquattro
« Reply #5 on: 23 January 2005, 22:45 »
How do you work that out? that the very worst diagnosis.
The head gasket could just be blown, even if the head is warped, it can be skimmed.
More likely as the geezer said, he uses it for short journeys, so its probably just condensation.
Take it for a really good thrash down the motorway, see if it clears up.
