Author Topic: got a bang sound help  (Read 3647 times)
Offline 123sparkiemarkie123
« on: 16 September 2010, 21:01 »
right been spending loads on my car and got new lower arms and fitted powerflex bushes into them and ever since i get a bang when i brake, check all engine mounts and nothing wrong but i change the dog bone mount to power flex and now the car vibrates but i just think thats to do with the powerflex dog bone mount.
the thing i want to no is where and what could this be banging( on the left or middle of the car)
plus is it normally for the vibrate?
Offline houston
Re: got a bang sound help
« Reply #1 on: 16 September 2010, 21:31 »
just when you brake? have to be bit more specific
« Reply #2 on: 16 September 2010, 21:46 »
yes sorry it is only when i brake and does not do it all the time but most of the time
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #3 on: 16 September 2010, 22:41 »
are you running standard suspension? could be a knackered shock
« Reply #4 on: 17 September 2010, 08:34 »
no its lowerd 60mm but i did check and thats all fine
Offline houston
« Reply #5 on: 17 September 2010, 08:59 »
are the pads tight against the disc? could be a sticky caliper, but then again it could be loads of thing, have you inspected the brakes recently?
Offline Dannygood
« Reply #6 on: 17 September 2010, 09:03 »
if you do find out what this is let me know coz mine does the same and its driving me mental :angry:
Offline jimbooboo
  • YUM YUM
« Reply #7 on: 17 September 2010, 10:04 »
Mine used to do it. So replaced discs and pads up front and it sorted the problem. Check the pads..
Offline james2
  • No scammers please.
« Reply #8 on: 18 September 2010, 01:41 »
mine does that front bushes ....
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
« Reply #9 on: 18 September 2010, 21:05 »
right had a good look friday night and change the drop links as i have fitted powerflex bushes into them and today i drove up to my dads like 1 hour drive there and same back and only felt it 3 times, but now its back soooo thinking what is it?
you change the brakes and it worked?
