Author Topic: got a bang sound help  (Read 3649 times)
Offline houston
Re: got a bang sound help
« Reply #10 on: 19 September 2010, 00:51 »
force the brake piston back, then apply the brakes, do this a few times and see if it cures it.
no need to remove caliper, just force the pads onto it using a lever through the hole in caliper
Offline 123sparkiemarkie123
« Reply #11 on: 19 September 2010, 12:03 »
ok i will try that monday and let you no how i get on
thanks
Offline Purely VAG
« Reply #12 on: 19 September 2010, 20:13 »
Does it do it when you accelerate hard aswell?
If so check tightness of rear wishbone arm bolts and subframe bolts.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
« Reply #13 on: 19 September 2010, 20:29 »
what nm tightness should the rear arms bolts and sub frames be?
Offline Purely VAG
« Reply #14 on: 19 September 2010, 20:46 »
Don't know as havnt got software on this laptop.
Use a crackbar and youll need 18mm and 21mm socket. Make sure theyre touch tight with that for a start. Don't want to be driving with them loose.
« Reply #15 on: 19 September 2010, 20:55 »
kool, think there tight but will check again
« Reply #16 on: 20 September 2010, 18:51 »
checked and everythings tight but still mkaing bang sound when i brake plus some times when i go over a bump
Offline houston
« Reply #17 on: 20 September 2010, 19:21 »
not your exhaust? hows your dog bone mount?
« Reply #18 on: 22 September 2010, 21:24 »
exhaust is fine and dog bone mount is a powerflex now so there all good, grrr just doing my head in
Offline CraigDavieBeattie
  • Golf mk5 Sport Tdi 4motion
« Reply #19 on: 22 September 2010, 21:33 »
I get a noise like a knocking sound when i move off after the cars been sitting for a while like in the mornings leaving for work, reversing out driveway then up a small hill just out my street i hear this noise and also after getting in the car after work too i get this noise.. It seems like its comming from straight down the middle? near the front passenger seat. Does anyone know this sort of thing? My mate in Kwik Fit said it might be down to my CAT ? its the same cat since the car was originally made. only 1 prev owner.
