think you mean the 2 bolts thru the metal bracket on the front of the box, if you fit em the wrong way they'll hit the chassis leg. no need to drop the subframe, what you do is unbolt the alloy gear linkage bracket thats bolted onto the box with 3 bolts thru the diff casing, then you can get the bigger mounts out
