Author Topic: Disconnecting the battery  (Read 1994 times)
Offline PenguinGTI
« on: 14 September 2010, 23:31 »
Hi there folks I am thinking about disconnecting the battery on the car. What are the risks?
Will I lose the settings on the car?
I have a map on the car. Will I lose it?
Or more simply, if I unplug the battery and leave it for half and hour will the car be the same when I re connect it all and start it
Offline Keithuk
Re: Disconnecting the battery
« Reply #1 on: 15 September 2010, 01:33 »
I have a map in my car but I don't use it.  :grin:
It shouldn't make any difference to the ecu settings. The radio code isn't needed either as VW's today, when you connect the battery backup it checks which radio you have and if it matches the code in the ecu the radio should work. I asked about the radio code when I picked mine up. Thats in the service database but you shouldn't need it. I said its my car my radio I want the code so they gave it to me. They said you would need the code if you took that radio out and fitted it in another car.  :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Steve30
  • Ed30 .
« Reply #2 on: 15 September 2010, 08:18 »
I did my car for a month connected it back when I came back off hoilday with no problems at all ! It sorts itself out once re connected  :wink:
Mine is not re-mapped though !!
« Last Edit: 15 September 2010, 09:46 by Steve30 »
Tiguan quicker than the Golf
Offline Das Auto
« Reply #3 on: 15 September 2010, 09:00 »
When my GTI went in for a new clutch/gearbox they had the battery disconnected for about a week as a result according to the revo texnician that is why my remap went bye bye got it installed again though for free
Offline KennyGTI
« Reply #4 on: 15 September 2010, 09:49 »
Weird that Das Auto. Maybe they flashed an update on the car? I have never had any problems with disconnecting the battery before with a remap. Not sure if this will be the same on the Golf but on my Polo I had to fully open and close the windows (keeping my hand on the switch) to get the auto close/open working again. Not sure if this was to reset the limits?
APR Stage 2+
