Author Topic: anyone know about spigot ring sizes?  (Read 4758 times)
Offline jasonnjane
« on: 12 September 2010, 10:26 »
just got a set of alloys that were too big for a corsa but look ok on my golf but need some spigot rings.
mine is a mk3 golf(4 stud) and unsure of corsa but they are 4x100.
Re: anyone know about spigot ring sizes?
« Reply #1 on: 12 September 2010, 16:47 »
57.1 for a golf
Offline jasonnjane
« Reply #2 on: 12 September 2010, 20:59 »
so whats the size of a corsa centre?
Offline Ben Lessani
« Reply #3 on: 12 September 2010, 21:13 »
Might be worth mentioning what Corsa exactly.
Offline jasonnjane
« Reply #4 on: 12 September 2010, 21:18 »
prob a 97 98 ish type corsa.
Offline jasonnjane
Offline BAHA
« Reply #6 on: 03 October 2010, 20:02 »
Hey Jason,
For VW golf,the centre bore is 57.1.
Offline Neo Badness
  • Feet are for pedals
« Reply #7 on: 06 October 2010, 12:12 »
As prev stated the golf 4x100 has a centre bore of 57.1mm.
iirc the centre bore of vauxhall 4x100 is 56.6mm :nerd:
So if you were fitting vauxhall wheels to a VW you would need to account for the differnce of 0.5mm centrebore by machining them.
Or use a large rubber hammer...
So, if my calculations are correct, you don't need spigot rings as they are for when the centre bore of the wheel is larger than the car you are fitting them to. Spigots help the wheel sit centrally and avoids undue stress on wheel bolts and potential wheel wobble/ fall off/ crash/ ditch/ flames/death etc. So as the wheel you are thinking of fitting has a narrower centrebore you don't need spigots :cool:
HTH
NB
*Edit the spigot rings link posted from ebay were 57.1 to 71.6 spigots which you would need if you were putting, say, Touareg wheels on, but not much else.
« Last Edit: 06 October 2010, 12:30 by Neo Badness »
Offline BAHA
« Reply #8 on: 05 February 2011, 20:54 »
Check your fitment at the link below
http://www.alloy-wheels-store.com/fitment-guide.html
