Author Topic: Rear Bushes  (Read 3782 times)
Offline AlexMozza
Rear Bushes
« on: 05 September 2010, 19:58 »
My rear bushes are on  the way out.
Where is best to get a new set from and how much do they tend to cost.
I know you can get different types.
Any help thanks!
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline ralphtown
Re: Rear Bushes
« Reply #1 on: 06 September 2010, 08:31 »
I always use GSF
RALPH
Offline AlexMozza
Re: Rear Bushes
« Reply #2 on: 06 September 2010, 17:42 »
Thanks for that :D
As it is making a banging noise when i go over bumps what do you think needs to be replaced bush wise?
The rear wishbone bush?
Sounds like metal hitting metal.]
Thanks!
2001 Satria GTi
Formula 3 Mechanic
Offline Benrevs
Re: Rear Bushes
« Reply #3 on: 06 September 2010, 18:04 »
I bought from GSF and fitted a set around 2 years ago and the new owner contacted me to say they have disintegrated!  Safest bet would be poly bushes, but they are a tad expensive.  There are no wishbones on the rear, they have trailing arms.  It could be the shocks and their bushes or the main axle bushes, best to get it in the air and have a good look.  The main rear bushes are a right ballache.. wouldn't recommend it to anyone!!
« Last Edit: 06 September 2010, 18:06 by Benrevs »
Offline AlexMozza
Re: Rear Bushes
« Reply #4 on: 06 September 2010, 18:22 »
Haha Thanks for that.
I'm only looking for a cheap fix, planing to uprate the whole suspension and bushes at a later date anyway :)
Do you need a press for either of them?
2001 Satria GTi
Formula 3 Mechanic
Offline Benrevs
Re: Rear Bushes
« Reply #5 on: 06 September 2010, 19:07 »
Getting them in isn't so bad, its getting the old ones out that is a bastard. You will need a selection of hitting devices, a few chisels, maybe a blowtorch, possible a drill and a VERY good temper! All will become clear when and if you decide to tackle them!
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
Re: Rear Bushes
« Reply #6 on: 06 September 2010, 19:57 »
great i gota do this shortly :cry:
.....the project.........
Offline archie837
Re: Rear Bushes
« Reply #7 on: 06 September 2010, 22:28 »
Woaaaah loadsa mk2 owners in here!  :smiley: I've been putting them off. Best quote I got was from a mate and he reckoned a twenny a side to do on top of the bushes.
Project longterm Airbanger.
PD150 Anni daily
Offline ralphtown
Re: Rear Bushes
« Reply #8 on: 07 September 2010, 09:04 »
There is a special tool for removal but my "man" made his own.
The main radius are bushes are a real b!tch.
They are located ,sort of,under the end of the sill.
Just follow the suspension arm to its mounting with the body.
Personally,I,ve never had any issues with GSF parts and as you plan to upgrade,well...I,d do that now.
If you waste time and money replacing worn out standard parts with new standard parts,you,re throwing good money away.
If you know what set up you want in the future,then I,d go all out for it now.
The car won,t pass an MOT anyway,so you may as well catch the bus for a while whilst the cars up in the air.
RALPH
Offline AlexMozza
Re: Rear Bushes
« Reply #9 on: 07 September 2010, 17:22 »
lol, i may get 'my man' to do it lol
2001 Satria GTi
Formula 3 Mechanic
