Author Topic: Rear Bushes  (Read 3779 times)
Offline AlexMozza
Re: Rear Bushes
« Reply #10 on: 08 September 2010, 18:47 »
I have looked under the car and it appears that it is the suspension bush that goes into the boot (the one with the spring on it...cant remember it real name :s) and not the one on the lower arm as first thought.
Is there a part number for it? the old one has crumbled away :s
Thanks!
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline DubSociety
Re: Rear Bushes
« Reply #11 on: 09 September 2010, 09:51 »
Trust me when I say this ... go Polybush, those nice Powerflex ones that cost approx £60.
You want to change them once, the old ones disintegrate too quickly and are an absolute basteward to remove!!!
Offline kr1s77
Re: Rear Bushes
« Reply #12 on: 09 September 2010, 18:44 »
hi all, i'm thinking about replacing my bushes next month. would this kit be ok.
http://cgi.ebay.co.uk/POWERFLEX-SUSPENSION-BUSHES-FULL-BUSH-KIT-VW-GOLF-MK3-/120606791206?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c14b99626
Thanks.
(sorry for hi-jack)
ASV 1.9 TDI 110
Offline AlexMozza
Re: Rear Bushes
« Reply #13 on: 09 September 2010, 18:58 »
Wow, I do need a set of them :P
Perhaps need a bit more than £60 first :D
2001 Satria GTi
Formula 3 Mechanic
Offline DubSociety
Re: Rear Bushes
« Reply #14 on: 11 September 2010, 08:01 »
Yeah thats the whole kit ... so your looking at £232 which is a decent saving as your buying everything and not just the rear beam ones like I did number (7) in the diagram on ebay.
And then around £200 odd for labour!
Offline AlexMozza
Re: Rear Bushes
« Reply #15 on: 11 September 2010, 19:40 »
Turned out just to be the rubber on the suspension strut between the bottom of the wheel arch and the strut...I feel a bit of a tit after all that :D
2001 Satria GTi
Formula 3 Mechanic
Re: Rear Bushes
« Reply #16 on: 11 September 2010, 21:06 »
Top mounts, did you replace both parts.
Offline AlexMozza
Re: Rear Bushes
« Reply #17 on: 11 September 2010, 22:12 »
Yes i have :D
Ill take it for a drive in the morning and see if that has fixed it all :D
2001 Satria GTi
Formula 3 Mechanic
Offline AlexMozza
Re: Rear Bushes
« Reply #18 on: 18 September 2010, 21:06 »
i have just finished replacing the rear bushes...my god, they were SO easy. took about 1 hour to get the axle of then about 10 minutes to get the old one out by drilling out and hitting it out. i made a tool myself to press the new one in..hey presto that took about 10 minutes too :D
whole thing took no less that 2 hours from stop to Finnish...hardest part was connecting all the hoses back up, took about 2 hours to do that on its own!
I thought it would take ages and be really hard to do...ill put the photos up of the tool i made :)
If anyone is thinking of doing this let me know and ill let you know how to make the tool :D
Alex
2001 Satria GTi
Formula 3 Mechanic
Offline vwscottie
Re: Rear Bushes
« Reply #19 on: 18 September 2010, 23:01 »
Alex
Please do i`m thinking of doing mine soon
