Author Topic: removing front wheel bearings  (Read 2031 times)
Offline retromk2craig
  • Mk2 GTI And Mk3 GTI
« on: 01 September 2010, 18:58 »
how do i remove front wheel bearings and hub from carriers??
MK2 8V        MK4 4 MOTION
Offline Ben Lessani
Re: removing front wheel bearings
« Reply #1 on: 01 September 2010, 19:13 »
I'm assuming you mean wheel bearing housing not carrier.
You remove the WBH from the car (disconnect bottom ball joint, remove suspension strut bolts, drive shaft). Then press out the hub (on a 20 tonne workshop jobby), then remove the retaining circlip, then press out the bearing - it usually disintegrates and leaves the old race on the hub, so you'll have to tap this off.
Offline Mr Blue
« Reply #2 on: 01 September 2010, 22:36 »
WARNING: If you cant get hold of a press. Do not smash the bearing with a hammer without a rag covering it. It can chip away and cut you real bad. Ware eye protection too. Very dangerous!
Can be done on a bench vice and a few heavy duty tools though
http://www.clubgti.co.uk/forum/showthread.php?t=97954&highlight=wheel+bearing+removal
Offline Simeon
« Reply #3 on: 01 September 2010, 23:07 »
Would a 12ton press be plenty adequate for the job, or 20ton more suitable? Price difference isn't that much and not worth buying the wrong tool for the job...
« Reply #4 on: 01 September 2010, 23:59 »
Would be better with a 20ton
Offline Simeon
« Reply #5 on: 02 September 2010, 00:50 »
ok, cheers
Offline AudiA8Quattro
« Reply #6 on: 05 September 2010, 21:10 »
12 ton will be fine. That's what i've got, and i've done quite a few.
