Author Topic: G60 brake vs S2 twin pot  (Read 2199 times)
Offline Gloves88
« on: 01 September 2010, 16:46 »
I have a set of g60 brakes, the type with the single piston and have been reading that a lot of people are putting on audi s2 brakes instead, the twin piston type....
Does any one know if I would see much of a braking difference between the two?
Also do the s2 brakes fit over the normal 280mm discs?
Offline Diamond Hell
  • Opinions я Us
Re: G60 brake vs S2 twin pot
« Reply #1 on: 03 September 2010, 21:06 »
What are you running that 280mm G60 calipers aren't enough?  :huh:
Offline Gloves88
« Reply #2 on: 04 September 2010, 00:15 »
Nothing at the moment but am in the process of putting a 1.8T in
I'm happy to use the G60's but can get a hold of a set of brakes from the S2 so was really just questioning whether its worth it?
Offline pegasus
« Reply #3 on: 06 September 2010, 21:47 »
yes, the s2 twin pot calipers will be a vast improvement over the g60 single's. More pistons = greater surface area of the pad in contact with the disc during braking, simples  :cool:
However, you should be aware that the s2 calipers are alot wider than g60's and may not go behind your wheels...  :wink:
1.8 20VT GTI
Offline emery1990
« Reply #4 on: 06 September 2010, 21:55 »
Are they quite alot heavier too?
  • Opinions я Us
« Reply #5 on: 07 September 2010, 23:39 »
Veedub16vgit seemed to think so.
If you need a vast improvement over G60 calipers with under 200bhp then do some leg exercises or learn to drive better.
Offline cняis
« Reply #6 on: 08 September 2010, 23:46 »
G60's/280's with 3rd party pads stop very well on mine
« Last Edit: 08 September 2010, 23:59 by cняis »
Offline danny_p
« Reply #7 on: 09 September 2010, 17:49 »
std g60's calipers provided plenty of brakeing for mine,  even when i had some really cheep pads tho they were better with posh pads.
the main reason i'll be upgradeing them as and when i put the car back together will be to reduce unsprung weight.    as to be fair with much more clamping force i recon it chould be possible to remove to much feel form the pedal
all the VW's have gone bar 1.
