Author Topic: Does this sound like the blue temp sender?  (Read 3458 times)
Offline jmsheahan
« on: 01 September 2010, 15:36 »
Hi all,
Few issues that have been plaguing my mk2 digi this week - wondered what the general opinion was on whether it's the blue temp sender at fault?
Car is reaking of exhaust fumes, popping on over-run, has a lumpy idle and is having trouble starting particularly when warm/hot. Plugs and exhaust are sooty so it must be overfuelling but not sure if it's the sensor buggering about with the fueling? Has only started doing it the past week or so.
Cheers  :smiley:
Re: Does this sound like the blue temp sender?
« Reply #1 on: 01 September 2010, 15:44 »
yeah i would say its the blue sensor, buy yourself a gen vag one the gsf ones are a bit pants
Offline jmsheahan
« Reply #2 on: 01 September 2010, 15:48 »
Cheers RJ
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 01 September 2010, 15:50 »
+1
VAG ONLY!!
For More Info Click To See;
Offline jmsheahan
« Reply #4 on: 01 September 2010, 15:55 »
+1
VAG ONLY!!
One on order. Seems the price has gone up a few quid though.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 01 September 2010, 16:10 »
Whats new!!
You dont expect them to get cheaper do you??? :tongue:
Offline kittie
« Reply #6 on: 04 September 2010, 21:27 »
Hmm I replaced the blue temp sender on mine a couple of years ago, with a VW item, and just replaced it again as am having all the problems described in the OP!
Also the temp sender never solved my problem of hot starts, I do wonder if the problem actually lies elsewhere or if the temp sender I originally got from VW was a duffer. Will have to see what this second one does if anything!
Offline jmsheahan
« Reply #7 on: 05 September 2010, 10:06 »
After putting the temp sender in a couple of days ago I'm in the same position.
Lumpy idle (car shakes a bit when at traffic lights etc), smells of emissions from the exhaust and pops a bit on over run. Oil temp is a tad high (upto 110 when giving it some) and it's still being a bugger to start when hot, fine when cold. Ignition timing has been done and the car pulls ok.
Possibly something to do with the MAF? Reading the bible RJ tuning guide would getting the CO set up again possibly help?
Offline kittie
« Reply #8 on: 05 September 2010, 11:55 »
Sounds like you're in the same position as me. I've had the CO set up properly on a proper machine which does sort the car out for a while but then it seems to soon slip back to where it was. It was suggested that it could be the errm air flow meter I think it is, I tried replacing mine with one from a lower mileage car but no joys. Might try getting a brand new meter or something next if this second temp sender doesn't sort it. Waiting to get it set up as the machine at the garage I use went up in flames the other day!! :undecided:
Offline glengus
« Reply #9 on: 06 September 2010, 07:53 »
i had the same prob with mine a few weeks ago.i tried changing sensors etc but still the same.
in the end i had to take the throttle body thing off and give it a a good clean and it seemed to fix it.
