Author Topic: Does this sound like the blue temp sender?  (Read 3456 times)
Offline jmsheahan
Re: Does this sound like the blue temp sender?
« Reply #10 on: 06 September 2010, 18:10 »
Thanks for the suggestions.
I think I'm going to book it into a garage to get the CO checked as it can't do any harm.
Offline mattk
« Reply #11 on: 09 September 2011, 14:19 »
I know this is an old topic but was there a resolve on this issue?  I have the same symptoms  :sad:
Mk2 Golf GTI 1985 8v Black
Mk2 Golf GTI 1988 8v White RE1900 GTi Engineering
Mk2 Golf GTI 1989 8v Royal Blue
Offline jmsheahan
« Reply #12 on: 09 September 2011, 20:29 »
The problem was a cracked valve in the end with mine  :undecided:
If your still on the original blue sender it's worth changing for the £15 they cost to be fair.
Offline mattk
« Reply #13 on: 09 September 2011, 23:11 »
Yup still on the original temp sender so will replace that. I can smell fumes when I have my drivers window down really badly, otherwise car runs fine when cold but pops on overun and uses more fuel than it did. Exhaust is sooty and plugs are too. Idle is fine and no cold or hot startup issues. Engine has done 215k so maybe valve probs here also?
Offline jmsheahan
« Reply #14 on: 10 September 2011, 10:25 »
Sound like it's just running rich. Have a look at RJ's tuning guide: http://www.golfgtiforum.co.uk/index.php?topic=33253.0
