Author Topic: central locking kits for mk2's  (Read 15042 times)
Offline Neo Badness
  • Feet are for pedals
Re: central locking kits for mk2's
« Reply #40 on: 28 September 2010, 18:54 »
ok, it was a ring aroudn the picture of the mk4 key.  its the only fob that comes with the kit :)
 :grin: I was being a blindo. I'm ill, leave me alone :grin:
this one!
http://www.rclick.co.uk/product_info.php?cPath=53&products_id=399
Says for a 4 door, assume I just leave one of them unplugged it'lb be fine? Mine is a 3dr. So one for the boot and the other two for doors leaving a spare.
Any one have problems getting the key cut?
If it is anything like the actual vw keys you can remove them from the fob (with a bit of fiddling) so theoretically shouldn't be any problem. Albeit I haven't yet got these specific keys so can't say 100% but I would go to a key cutter who is happy to do them or specialises in motortrade.
Offline weazgti
« Reply #41 on: 28 September 2010, 20:58 »
Igot a bag of blank keys with no ends,just the bladed bit.
See what your saying about the fob but i didnt have one to start with,just had the old vw key which is black round the outside and vw in middle.
Offline Neo Badness
« Reply #42 on: 28 September 2010, 21:09 »
This used to have pics but gives you the jist
http://www.clubgti.com/forum/archive/index.php?t-113822.html
« Reply #43 on: 29 September 2010, 09:05 »
i didn't have a problem, chap took my old key and blank and cut it to perfection. if it doesnt work just means they haven't aligned the 2 keys up properly in the cutting machine.
as for 2/4 door kits they're the same, just means you have 2 spare cl motors and wiring.  fit these to your petrol flap and tailgate using vag cl mechs with the vac motors taken off and a bit of head scratching ;)
Offline Cory
« Reply #44 on: 11 November 2011, 17:41 »
ive just bought the rclick system. where have you guys put the brain, and what 12v supply did you attach it to?
Offline weazgti
« Reply #45 on: 11 November 2011, 20:03 »
I just put the brain above fusebox and tapped into a live red wire near it.
Offline Cory
« Reply #46 on: 11 November 2011, 20:08 »
ok, im not very savvy with electrics so not super confident with doing that. could i not get a longer piece of wire, and feed it straight from the battery and use a connector to attach the new wire from the battery to the one coming from the brain? problem solved?
also where will i find a good earth?  :grin:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #47 on: 11 November 2011, 21:41 »
Why go to all that trouble... Read RJ's FAQ in Mech section the live wires are at the rear of he fusebox...
Earths are on a block above the Fusebox beside the steering column (Brown Wires)...
Is yours a CE1 (dash mounted Hazard) or CE2 (steering column Hazard) Fusebox??
For More Info Click To See;
Offline Cory
« Reply #48 on: 11 November 2011, 21:50 »
it would be a CE1, i just know pretty much nothing about electrics, and dont want to b*gger up my fuse box
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #49 on: 11 November 2011, 21:56 »
http://www.golfgtiforum.co.uk/index.php?topic=44637.0
Page 1 Bottom & Page 4...
P - red - battery +, ignition switch pin 30, electric window relay pin 87, headlight washer relay pin B/30 & f/injection relay pin 30 (K-Jet f/inj)
If In doubt drop RJ an Email...
