Author Topic: central locking kits for mk2's  (Read 15018 times)
Offline mk2bal
« on: 29 August 2010, 16:45 »
anyone bought an ebay c/l kit to work with a toad alarm. not sure what to buy, they all seem to be ones that come with their own crappy key fobs, can i wire them up to the toad and bin the sh!tty fobs? not even fussed bout it doing both doors, just mine will be fine.... any ideas?
Offline Jay77
Re: central locking kits for mk2's
« Reply #1 on: 29 August 2010, 16:49 »
ive got one of ebay and would be interested. If you put an alarm would you have to use both key locks
Offline The Mighty Elvi
  • I'm better than you today.
Offline Haribo!
« Reply #3 on: 29 August 2010, 18:01 »
http://www.rclick.co.uk/index.php?cPath=53
Ive recently put a cheaper version of this in my golf, works perfectly but I kinda fancy this anyway cause of the key/fob, and separate boot button.
Offline Ben Lessani
« Reply #4 on: 30 August 2010, 00:21 »
Wasn't this asked a couple of days ago?
Most c/l kits have a 2 wire connection for close/open that is pretty much universal as far as hooking up to alarm systems go
« Reply #5 on: 31 August 2010, 10:32 »
haribo: most of the aftermarket cl kits use the same plug on the brain, so you could get the rclick kit and just swap the brain over to upgrade to the rclick fobs :)
did this on my mk2 first to convert it to remote cl, then again when i bought the rclick kit. the wiring and cl motors were all left alone
Offline Haribo!
« Reply #6 on: 31 August 2010, 11:42 »
ah good, I was hoping I could do that, although in the description it said something about silent operation, any idea if this means the motors are slower and less violent than the cheaper ones?  if thats the case then im swapping out the motors too, I can still keep the cables :D
« Reply #7 on: 31 August 2010, 13:57 »
i used one of the rclick motors in my passenger door as the one in there packed in, cant say it sounds any different to the rest but then ive never really listened to it  :grin:
swapped over just fine though, same shape and wires :)
Offline Haribo!
« Reply #8 on: 31 August 2010, 14:39 »
ah ok, well il investigate.
I may have to swap the wiring over anyway tho cause of an auxiliary wire or something for the separate boot unlock button?  or something like that.
« Reply #9 on: 31 August 2010, 14:40 »
the boot pop and the other bits are on a seperate plug :)
