Author Topic: central locking kits for mk2's  (Read 15030 times)
Offline Haribo!
Re: central locking kits for mk2's
« Reply #10 on: 31 August 2010, 14:45 »
the boot pop and the other bits are on a seperate plug :)
ah, so il still need to run new cables to my boot?
« Reply #11 on: 31 August 2010, 15:31 »
aye, you only need a live feed tho, the earth you can piggy back onto the wiper earth. if you didint want your rear wiper could take it off and use the wires from that for the pop. the wiper wires come out into the C pillar, could unplug it there and plug in your boot pop wiring, that would save doing any modification to your wiring loom then
Offline Haribo!
« Reply #12 on: 31 August 2010, 15:46 »
well ive got wires going back there anyway for the existing central locking motor I put in last week, so I could just connect the new wires to them? They pass thru my boot at the mo cause they come from the motor in my petrol flap.
« Reply #13 on: 31 August 2010, 16:17 »
you could use them but you would obv loose the central locking in the boot, cant have the cl and boot pop running thru the same wires see
Offline Haribo!
« Reply #14 on: 31 August 2010, 16:19 »
hmm, im confused now, I thought that the boot button with that particular kit just unlocked the boot central locking motor, is there an extra motor in the kit for a boot pop aswell?
« Reply #15 on: 31 August 2010, 16:32 »
oh no, what its for is to pop the boot open like on posh motors!  the central locking will still work as before to lock and unlock the boot and petrol flap :)
Offline Haribo!
« Reply #16 on: 31 August 2010, 16:35 »
thats odd, it doesnt say it that it includes any sort of boot release motor but it does include "boot release" as a feature and has a boot button on the fob...
am I supposed to use on of the standard motors in the boot?
« Reply #17 on: 31 August 2010, 16:43 »
yeah the boot pop motor/solenoid isn't included as std, though they do sell a kit for it.  you can try using one of the cl actuators and a rubber band so it retracts once popped, im sure i read that someone did that somewhere?
Offline Haribo!
« Reply #18 on: 31 August 2010, 16:51 »
ah bollockz to that, I can open the boot with the button like a normal person. save myself faffing about with it.
Offline Ben Lessani
« Reply #19 on: 31 August 2010, 18:41 »
I just used one of the rear door solenoids for the boot pop, I'll see if I can dig out the picture of how it is setup.
