Author Topic: Mk2 rear end wallow  (Read 4448 times)
Offline Mr Blue
Re: Mk2 rear end wallow
« Reply #10 on: 28 August 2010, 23:02 »
I'd rather fit genuine parts when it comes to bushes. They are not easy to change. May aswel do it once :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #11 on: 28 August 2010, 23:05 »
Couldn't agree more....
Sounds to me like your shocks...
I fitted Boge turbo's to mine all round... Bought all new bump stops Top mounts & bolts etc from VW seems the last ones lasted 18 years so that will do me...
For More Info Click To See;
Offline jmsheahan
« Reply #12 on: 28 August 2010, 23:14 »
Too true  :smiley: I've only heard good things about Topran though.
X4MGS - how much did it set you back for the top mounts and associated bits from VW if you don't mind me asking? Just priced it up on vwspares - would be good to compare to genuine.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #13 on: 28 August 2010, 23:17 »
For fronts and rears I think it was about £85.00 but not sure as I did buy other stuff too...
Offline jmsheahan
« Reply #14 on: 28 August 2010, 23:25 »
Cheers, working out at about £45 odd on VW spares so sounds like genuine shouldn't be too much more.
Thinking of the Bilsteins from eurocarparts or possibly these shock wise
http://www.vwsonline.co.uk/car_parts_bristol/vw/golf/golf2/rearaxle/191-513-033j.html
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #15 on: 28 August 2010, 23:35 »
I would phoe the stealers to get a proper price before you go and order stuff...
I have to say that after my recent problems with temp senders etc... I am going more and more towards ONLY buying VW parts from now, as the patten parts may seem ok and are cheaper, they just don't seem to last...
Offline jmsheahan
« Reply #16 on: 28 August 2010, 23:37 »
Agreed but as above it depends what you buy really. Totally agreed on the senders though - had a pattern oil pressure switch that leaked and a temp gauge sender that under read.
Offline bodga
  • F reg GTI 16v
« Reply #17 on: 29 August 2010, 16:44 »
I tried the stealers for my rear shocks first, it worked out to @£150 with the VAT so i left it, thats all i paid for the car :grin:. ive had decent priced oil and filters from stealers thou.
vws, ive had a temp sender from there, and a gear linkage repair kit from there, they have been ok. ring to order thou, i ordered online, and it got messy. i didnt read the message on the home screen or it wasnt there :undecided:
