Author Topic: Mk2 rear end wallow  (Read 4449 times)
Offline jmsheahan
Mk2 rear end wallow
« on: 28 August 2010, 20:57 »
Apologies if this is a bit of a vague description but I've notice my mk2 handling a little oddly the past few days.
The best way I can describe it is the back end feels as though it wallows when you put it into a corner. The body rolls but front stays planted, rear feels like it wants to step out but then sticks. Quite fun to start with but a little unpredictable  :rolleyes:
Whipped the jack under it earlier and got the wheels off. No sag, car sits at the level it always has done. Both shocks look old but don't look particularly knackered. One was a little weepy perhaps but it certainly wasn't ****ing out and the struts looked dry, bar a bit rusty. Tyre pressures are 30 on the front and 28 at the back, and are brand new Uniroyal Rainsports.
This is how they are looking:
Beam bushes - looks a little crusty down there but couldn't feel any obvious play and there's no knocking or noises at all. Are there any fundamental signs that the rear beam bushes are shagged? Cars done 150k so it's likely they are probably past their best!
Pushing down on the boot the suspension seems to compress and spring back ok but I haven't taken the shocks off.
Thanks  :smiley:
Offline bodga
  • F reg GTI 16v
Re: Mk2 rear end wallow
« Reply #1 on: 28 August 2010, 21:27 »
any play in the wheel bearings? tightnening them made a difference to mine.
 i replaced the rear shocks on mine last wk, take the shocks off the car, remove the springs, push the rod into the shock, if the rod doesnt return its shagged (them bump stops should have the dust skirts attached to them) :grin:
Offline jmsheahan
« Reply #2 on: 28 August 2010, 21:30 »
Wheel bearings seem fine, gave everything a good once over, no play in them. It's odd, it's only started doing it this week. It's like driving a jelly  :laugh:  Like I say though no noises or tell tale clunks.
Did you replace with standard items? If so where did you get them from mate?
Offline cняis
« Reply #3 on: 28 August 2010, 21:32 »
mine had new rear beam bushes fitted before i bought the car (had pics to prove it) but the new beam bushed failed within 6 months.
the car would have a delayed steering reaction, it was ok around long corners but was meandering down straight roads (i was forever correcting the steering). It was so bad i refused to drive it for my safety!
there was no knocking or creaking, just unwanted 4 wheel steering!
when we took the bushes out, they fell apart! the rubber came out in 3 pieces!
Offline jmsheahan
« Reply #4 on: 28 August 2010, 21:37 »
Not so good!  :undecided:
To be fair I think they could probably do with being replaced if they are still the original factory ones but it's a real ball ache having to drop the beam to do it. I just don't really have the time right now. The car tracks in a straight line, it's just the corners that are the problem.
Offline bodga
  • F reg GTI 16v
« Reply #5 on: 28 August 2010, 21:48 »
mine has passed its MOT today, advisory "play rear wheel bearings" :shocked: i set them with slight play????
i had the shocks from eurocarparts "bistien", £29 each i think :huh: my old shocks were fooked, didnt realise untill i took them off thou because i was unhappy with the handling. had the bump stops from there as well. @£13 set
Offline jmsheahan
« Reply #6 on: 28 August 2010, 22:00 »
Cheers. They the gas ones rather than oil? Would be running them with 60mm lowering springs. Sorry to bombard you with questions  :grin:
Offline bodga
  • F reg GTI 16v
« Reply #7 on: 28 August 2010, 22:08 »
no worries, they are gas for the valver yes. ive just got standard springs its still low thou, just about fit two fingers between the rear arch and tire
Offline Mr Blue
« Reply #8 on: 28 August 2010, 22:31 »
60mm lowering springs with standard shocks?
I suspect the shocks are weak in that case.
Changing the rear bushes on mine in a few weeks. Just over £30 each from VW :shocked:
Offline jmsheahan
« Reply #9 on: 28 August 2010, 22:43 »
On the car when I bought it. It's reasonably low but not slammed low so there's a chance they may be 40's I guess.
£30! Ouch! You can get topran ones for £11 odd quid.
