Author Topic: 280mm front brakes (hoses too short)  (Read 2544 times)
Offline Mr Blue
« on: 28 August 2010, 16:52 »
As title. Did a search but cant find anything on flexy hoses.
Fitted 280mm brakes on the late 8v.
Everything fits (including the wheels without spacers) but the front flexy lines seem too short.
Its just on full lock they look like guitar strings. :laugh:
Im guessing this is not normal?
« Last Edit: 29 August 2010, 00:29 by Mr Blue »
Offline sidecarphil
Re: g60 front brakes (hoses too short)
« Reply #1 on: 28 August 2010, 17:04 »
I bought new ones when i fitted my G6's to my late 8v
there is a differant part number but i dont know why ??
guitar strings  :shocked: :shocked:
At least it isn't G strings  :laugh: :laugh:
Offline danny_p
« Reply #2 on: 28 August 2010, 20:14 »
have you got the hardline standoffs ?
all the VW's have gone bar 1.
Offline Mr Blue
« Reply #3 on: 28 August 2010, 21:22 »
No danny. Just put the lines straight onto the caliper.
The calipers are Girling 54 if that helps.
The right brake caliper flexy line has enough slack but when the left wheel is on full lock the flexy line is stretched out almost.
Im not comfortable with this as the flexy line could touch the spinning wheel too.
Any part numbers for the missing bit and can i get it and europarts?
EDIT:
Think ive found the answer.
1 171611701L  brake hose M10X1X335 2
(1) 535611701  brake hose M10X1X350 2 RALLYE GOLF
thanks
« Last Edit: 29 August 2010, 01:10 by Mr Blue »
Offline danny_p
Re: 280mm front brakes (hoses too short)
« Reply #4 on: 29 August 2010, 03:32 »
on mine,i havea golf rallye setup  i have the same callipers but they have a section of hardline comeing off them and the brake flexi hose has two femail ends as opposed to the 256 setup where the flexi goes straight into the caliper.  if your hose goes straight int the caliper i would have thought it would fit witout the hardline standoff tho. can try and get you some pn's when sober if you want tho
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #5 on: 29 August 2010, 10:08 »
on my mk2 ABF ive got hoses off a seat toledo which are plenty long enough. Its a wide track setup up on the front too. they also have a section of hard line comming off them
Offline Mr Blue
« Reply #6 on: 29 August 2010, 14:37 »
thanks for the tips.
Do any vag cars come with banjo type front brake lines?  the seat ones may stick out too close to the inside of the wheel like they are now.
my setup
if i cant find banjo lines then ill copy these (yellow circle)
looking at the pics now I noticed the bleed nipple and brake lines swapped over. Is this ok?
Im new to big brakes
 :smiley:
« Last Edit: 29 August 2010, 15:15 by Mr Blue »
Offline robiwill
« Reply #7 on: 29 August 2010, 19:12 »
christ you didnt mess about getting those fitted did you ;-)
Offline Mr Blue
« Reply #8 on: 29 August 2010, 20:05 »
thanks for those. changed the wheel bearings too  :laugh:
Offline danny_p
« Reply #9 on: 30 August 2010, 00:12 »
bleed nippel should be at the top  if it's not it can make bleeding a pita,  but it dosent actualy affect the performance of the caliper provideing you managed to bleed it
