Author Topic: My Golfs driving me mad  (Read 5566 times)
Offline Griff76
  • If only everything in life was as reliable as a...
« on: 26 August 2010, 18:00 »
Been having loads of grief with my golf again!!! Its been cutting out and some times not starting since i got it. I was told it was the immobilizer so i had the alarm serviced. Since then it wouldnt start(nothing going to the starter) so i changed the ignition barrell as it was dodgy, it started no problem fine for a few days. Next thing its running fine then starts cutting out on the motorway like thers no fuel supply then not starting for 5 mins!!!!girlfriend and kids in the car not happy!!!!!! So next i cleaned the throttle body out etc and changed the fuel pump relay n put some fuel treatment in the tank. Been fine for a few days but just cut out at the lights and wouldnt start again for 5 min. Had to push the f**k*r again its doing my head in. any ideas please. Could it be the coil pack? frustrated golf owner, griff
Offline zdebx
Re: My Golfs driving me mad
« Reply #1 on: 26 August 2010, 18:45 »
Could be the dizzy?
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline danmusic24
« Reply #2 on: 26 August 2010, 19:27 »
coil mate! defo..golfs seem to burn them out fast!
Offline fozziie
  • psn: fozziie
« Reply #3 on: 26 August 2010, 23:34 »
my coils on the way out, if i ever go out anywhere in mine and it starts raining, i dread trying to restart it! feels like its running a bit rough at times too.
« Reply #4 on: 27 August 2010, 09:31 »
what engine is it? could be crank sensor if 16v or later 8v
Offline DubSociety
« Reply #5 on: 27 August 2010, 11:04 »
As above, on my 16v it was the crank sensor. I replaced everything and in the end it was the crank sensor.
Offline javalin
« Reply #6 on: 27 August 2010, 11:21 »
would check crank too if it has one.  Mine looked like:
http://javalins.wordpress.com/2010/03/13/dodgy-sensor-wiring/
How do you have your alarm "serviced" out of interest?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Griff76
« Reply #7 on: 27 August 2010, 16:46 »
Could be the dizzy?
Yeah cheers bud gunna check the coil pack first if not i think it could be dizzy
Offline Griff76
« Reply #8 on: 27 August 2010, 16:50 »
Its a 2.0 8v (agg) thought it might be that before when my rev counter went crazy but there is no crank sensor its built into the dizzy so could be this. Cheers bud
Offline Griff76
« Reply #9 on: 27 August 2010, 16:58 »
James
its a toad alarm i looked them up on the internet and they sent out some clifford blokes. It was about £150 so not cheap but it all works now central locking, siren etc. Had to get it checked out because everyone was saying it was the immobilizer (including qualified mechanics)
