Author Topic: Will these fit ok  (Read 1395 times)
Offline Streetfighter313
Will these fit ok
« on: 23 August 2010, 17:07 »
Trying to find out will these pipes fit a GTD will I have to do much modification with the exhaust system to make them fit ok.
Offline PenguinGTI
Re: Will these fit ok
« Reply #1 on: 23 August 2010, 17:16 »
well your basically going from a side exhaust to a central exhaust. I'm no mechanic but I can imagine that requiring a little work.
« Reply #2 on: 24 August 2010, 05:04 »
The exhaust back box on any mk5 or mk6 Golf runs sideways accross the back of the car so the back box fitting won't be that difficult.
The Golf R & Leon Cupra R (and optional on the Leon K1 and TDIs fitted with the Aero kit) run this type of rear exhaust box, plus there are numerous Golf GTI mk5s running around with Golf R32 rear boxes and lower bumper sections. So the actual exhaust part is a fairly simple aquisition.
The main difference on the mk6 is that the Rs bumper is completely different, so it's not just a matter of replacing the lower section like on a mk5.
I would think that with a bit of plastic welding and rear diffuser cutting it shouldn't be that daunting a prospect if you're really up for it.
