Author Topic: oil temp  (Read 3753 times)
Offline Lee
  • Oiiii stop your dog sh!tting on my lawn
oil temp
« on: 13 August 2003, 20:46 »
Allo allo
My 16v has been running hot the last couple of weeks, just like every other car in england. The problem im having is the oil temp now sits at 108-110 all the time. Before this hot spell it always sat at 102-104 has anyone elses golf been doing this or is it just my poxy car. :'( :'( :'( :'( :'(
ps i have just topped up the antifreeze with some of that G12 plus stuff from vw dont know if thats doing it or not :'(
« Last Edit: 13 August 2003, 20:53 by Lee »
Ape shall never kill ape
golfvr6
Re:oil temp
« Reply #1 on: 13 August 2003, 22:22 »
Sounds quite hot, is your coolant temp that high as well?
Offline Lee
Re:oil temp
« Reply #2 on: 13 August 2003, 22:33 »
Its only slightly higher than normal just over halfway. I replaced the rad cap the other day for a blue one i think it was doing this before though. I have just replaced the dizzy cap and spark plugs aswell for genuine vw parts.
« Last Edit: 14 August 2003, 13:11 by Lee »
golfvr6
Re:oil temp
« Reply #3 on: 14 August 2003, 14:53 »
I would probably get the oil pressure tested, to make sure the pump is working ok.
Offline stew8vmk2golf
Re:oil temp
« Reply #4 on: 14 August 2003, 14:56 »
how would you test the oil pressure
golfvr6
Re:oil temp
« Reply #5 on: 14 August 2003, 23:56 »
I think you might have to go to a garage to get the pressure tested, you may be able to buy something, have to have a look around. However if you haven't got a splash sheild in your cam cover(i'm sure 16v hasn't), leave the car overnight, take the oil cap off, start the car and see how quick the oil flows at the top of the cylinder head. It should come up very quickly. Another thing to try is to take off your oil cooler and clean it out, it may be clogged up.
Offline Lee
Re:oil temp
« Reply #6 on: 15 August 2003, 13:02 »
Ok golfvr6 i will give it a go and let you know.
Offline Lee
Re:oil temp
« Reply #7 on: 16 August 2003, 17:03 »
I have just started the golf up (cold) without the cap on and oil was spitting out then a couple of seconds latter it was very messy. The oil pessure must be ok. I have been driving the car today and the oil temp is now at 104 most of the time i think it must have been the hot weather maybe. I have noticed the water level is slowly going down this has only started since my water level sensor seal went. I have replaced this and its not leaking from that. I have looked for leaks but not found any yet. I topped the water up with g12 plus but noticed that richandhazel used the same stuff and it made his mk1 leak all over the place. whats going on with this stuff anyone know. :'(
« Last Edit: 16 August 2003, 17:07 by Lee »
Offline richandhazel
Re:oil temp
« Reply #8 on: 19 August 2003, 00:18 »
Mine is OK now....sorted. Drove to Norwich and back (165 miles each way) and my oil temp hit around 102/4 deg sometimes hit 108 deg when I was driving it hard............I thought that was fine..............?
« Last Edit: 19 August 2003, 00:19 by richandhazel »
Offline Gambit
Re:oil temp
« Reply #9 on: 21 August 2003, 16:57 »
clean out the oil cooler at the top of the oil filter, just take of the two pipes and run hose water thru it
i cleaned mine per chance when i split one of the hoses.
the amount of gunk, rust, chunks of crap that came out was frightening
Craig
91 16v
