Author Topic: HU problem  (Read 2502 times)
Offline Len
HU problem
« on: 19 August 2010, 13:47 »
It cut out on me!  :angry:
This was at a quite high volume up at 24 on my Alpine scale, I usually never go above 20.
The HU just cut out and only came back when I reduced the volume.
Was the vibrations too much for it? I mean I could feel the back of the seat vibrating!
www.sas.org.uk
www.the-ace.org.uk
Offline DubSociety
Re: HU problem
« Reply #1 on: 19 August 2010, 14:49 »
I think its just a defence mechanism ... it cuts out and comes back on, basically telling you your sound setup can't hack it!
EDIT: overload protection
« Last Edit: 19 August 2010, 15:08 by DubSociety »
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: HU problem
« Reply #2 on: 19 August 2010, 15:38 »
Does your headunit have a large on-board amplifier (i.e. 45 or 50 watts per channel)?
Had you been running it high for a prolonged period of time?
If so it's likely to be a heat issue rather than one of vibration.
The greatest leveller of them all - the Carousel
Offline Len
Re: HU problem
« Reply #3 on: 19 August 2010, 16:03 »
Its a 4 x 60 amp in the HU -  Plus the amp for the sub and door speakers.
And no I wasnt running long a couple of tunes at normal volume than I switched to Comfortably Numb and wacked it up!
So wasnt at that volume for more than say a minute.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: HU problem
« Reply #4 on: 20 August 2010, 09:17 »
Just a thought - I dont think I have the sub amp set for clipping.
Could that interfere with the HU?
www.sas.org.uk
www.the-ace.org.uk
Offline DubSociety
Re: HU problem
« Reply #5 on: 27 August 2010, 13:59 »
Len just so you know, my Alpine headunit died on me recently ... what I mean is, its got a fault, it doesn't like being used with an external amp, so keeps poppin when I move the volume knob from 0 to whatever volume. (Originally thought it was a ground issue) And everytime I change tracks ... not to mention cuts itself out when I put the volume above 21.
Now ive replaced my headunit with a delphi grundig one with all door speakers and my 10" sub connected to a amplifier, I can push the sound ridiculously high without any problems. Its suprising how a cheap setup sounds after wiring everything up and buying items that compliment each other in terms of watts/ohms!!!
Just food for thought ... you never know, the head unit may be on its way out, starting to act funny n all that ...
Offline Deano2711
  • 1992 VR6
Re: HU problem
« Reply #6 on: 27 August 2010, 16:00 »
And people keep telling me that you mellow out with age.....your an inspiration to us all Len Mate  :grin: :grin:
Offline Len
Re: HU problem
« Reply #7 on: 27 August 2010, 16:40 »
CD's I bought recently - Chicane and Pendulum. They inspire?
Hmm sounds like whats happening on mine then!
I did buy the HU secondhand so maybe it is on its way out! :sad:
Oh well will just have to moderate volume! :cry:
www.sas.org.uk
www.the-ace.org.uk
