Author Topic: gearbox noise on my mk2 16v *help needed*  (Read 1184 times)
Offline darren182
« on: 16 August 2010, 20:53 »
hello guys n gals,
                        i have recentley had to put a gearbox in my golf because the diff blew i also fitted a new clutch, the car now drives really good and is completely different to before but i have a noise when i press the clutch the only way i can descrive the noise is like a rough hissing noise but only when i dip the clutch,really want to sort the problem before it gets worse, so help is needed really bad cheers for looking
Offline theclash
Re: gearbox noise on my mk2 16v *help needed*
« Reply #1 on: 16 August 2010, 21:14 »
did you change the thrust bearing when you did the clutch
Offline Agreeable Slick
  • Unit
