Author Topic: 8v>16v Master Cylinder...  (Read 1432 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 16 August 2010, 15:35 »
I went to change the MC on my 8v to the 16v unit and noticed it's got 4 pipe outlets, as opposed to two on my current one. What are these extra two outlets for?
Offline Simeon
Re: 8v>16v Master Cylinder...
« Reply #1 on: 16 August 2010, 16:20 »
Can block off the two extra or run single pipes to each brake if you fancy it
Offline boxer1968
« Reply #2 on: 16 August 2010, 21:21 »
hello didnt want to start a new topic as i have same question what have you blanked off spare outlets with? maybe a daft question but i have the same problem with a new 22mm m/c
Offline boxer1968
« Reply #3 on: 16 August 2010, 22:34 »
found out what i needed by searching :grin:
« Reply #4 on: 16 August 2010, 23:34 »
So the 16v had 2 more brakelines than the 8v?
« Reply #5 on: 17 August 2010, 10:12 »
no it didnt, still uses 2 lines. just the factory fit mcs have 2 outlets in use, new ones tend to have 4. as for blockign them off, can use bleed nipples :)
