Author Topic: Oil Cooler  (Read 1821 times)
Offline Sam
  • Sam I am
Oil Cooler
« on: 15 August 2010, 23:52 »
My oil temp sits at 98, so i wanna get it back down to 80 which is near enough standard temp. My turbo has an oil feed to it and from it, would i simply be able to split the outlet line and push it though a front mounted oil cooler and then let it drop the sump? Is it that simple or am i missing somthing??
Offline Mew
Re: Oil Cooler
« Reply #1 on: 16 August 2010, 00:17 »
What's wrong with 98 degrees?
Offline Diamond Hell
  • Opinions я Us
Re: Oil Cooler
« Reply #2 on: 16 August 2010, 09:35 »
It's two off 100, which is simply not good enough.
Stop mithering about it and go back to what you were doing previously.
Offline Ben Lessani
Re: Oil Cooler
« Reply #3 on: 16 August 2010, 09:39 »
+1
90-110 is a safe operating boundary for OIL.
75-90 is a safe operating boundary for WATER.
Offline Horney
Re: Oil Cooler
« Reply #4 on: 16 August 2010, 09:41 »
If you want one you need a sandwich plate off your filter pick up and then an oil cooler in the front grill. Have a look on eBay for Mocal ones.
98 is OK though.
Nick
Offline Sam
  • Sam I am
Re: Oil Cooler
« Reply #5 on: 16 August 2010, 12:35 »
Ah ok, just its always used to sit at 80, then put different oil in (much better oil) and it sits alot higher just thought that it was a little to high.
I will go back to what i was doing previously  :undecided:
Offline Ben Lessani
Re: Oil Cooler
« Reply #6 on: 16 August 2010, 13:13 »
Well, there is always the risk that your oil temp gauge is reading wrong and that your new oil is too thin and breaking down when hot.
Offline fishnchipsx2
Re: Oil Cooler
« Reply #7 on: 16 August 2010, 18:23 »
I'm surprised it's not higher with a turbo in this weather!
Offline Sam
  • Sam I am
Re: Oil Cooler
« Reply #8 on: 16 August 2010, 21:34 »
Its only a baby turbo, could go much much bigger but its my daily. I will just leave it how it is then if all seems well with you guys! Thanks for the advice  :smiley:
