Author Topic: Alhambra radio - does it need coding?  (Read 1852 times)
Offline jaydubveedub
« on: 12 August 2010, 10:04 »
We've recently put a new head unit in my uncle's 2003 Alhambra. It's the standard 'Scala' head unit. The old one had packed up.
Anyway the new one seems to work but we don't have the code for it. Can I just get the code and tap it in or does the head unit need to be coded to the car with VAG-COM?
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline troublestarter
Re: Alhambra radio - does it need coding?
« Reply #1 on: 12 August 2010, 10:10 »
you just need the code it doesn't need to be done via vagcom
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
« Reply #2 on: 12 August 2010, 11:59 »
Cheers.
Would you recommend using one of these radio code website, or should I just take it down to my local car audio place?
« Reply #3 on: 12 August 2010, 12:58 »
as long as you put the correct serial number in the online ones are fine
