Author Topic: QUICK HELP PLEASE double din fitting  (Read 2395 times)
Offline chol_gti
« on: 11 August 2010, 20:24 »
hey all i just bought this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170517375402&ssPageName=STRK:MEWNX:IT then i bought this to fit it http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180498170084&ssPageName=STRK:MEWNX:IT
however i cant get it to fit correctly, i can get the din in the fascia however the buttons that are supposed to realease wont because its to tight.
also when the facsia and din is fitting how do you remove it again once fitted?
lookiing for quick replys please thanks
Offline chol_gti
Re: QUICK HELP PLEASE double din fitting
« Reply #1 on: 11 August 2010, 21:09 »
someone???  :sad:
Offline troublestarter
« Reply #2 on: 12 August 2010, 05:52 »
did you use screws through the side of the fascia to mount the stereo??
the reason i ask is that the fascia could be being pulled in too much at the sides therefore causing the button issue
i presume they work fine when not in the fascia??
the stereo i would imagine did not come with a metal cage (most of these cheaper units don't)
as for removing it from the dash in the fascia it will (or should) just push out.However the side screws in the fascia can make it very difficult to get out from the dash as the screw heads sometimes protrude past the trim
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline chol_gti
« Reply #3 on: 12 August 2010, 07:15 »
no i didnt put screws in and fix it in properly as i was scared that if i did it may never come out again haha.i can only the the din to fit in to the fascia before i install i. if i try putting the fascia in first then try putting the din in it wont fit to small.
yeah the fascia has 2 like cut outs on one side but i dont understand when fitted how you would get to them? are they supposed to be put to the top or the bottom when fitted?
thnx m8
« Reply #4 on: 12 August 2010, 08:11 »
the stereo screws to the fascia theough the sides there should be 2 screw holes either side of the plastic fascia that should line up with 2 mounting holes on either side of the stereo
if the stereo doesn't fit properly in the fascia then the stereo may well in that case need a universal metal cage and plastic surround instead
something like this for example
http://cgi.ebay.co.uk/Universal-Double-Din-Cage-Kit-182x103mm-Radio-Headunit-/200503379025?pt=UK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Speakers_PP#ht_598wt_911
Offline chol_gti
« Reply #5 on: 12 August 2010, 19:19 »
i might have sorted it with fascia but how do i remove it if needed?
thanks
« Reply #6 on: 12 August 2010, 20:38 »
you just need to prize the fascia out carefully with a trim tool preferably
