Author Topic: Where to feed Vac pipe for Boost Gauge  (Read 5288 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
« on: 11 August 2010, 15:18 »
Wheres the best place to feed the Vac pipe through the bulk head on a 1.8T to connect to a boost gauge in the drivers vent?
Offline T_J_G
Re: Where to feed Vac pipe for Boost Gauge
« Reply #1 on: 11 August 2010, 15:29 »
Not the bonnet release cable grommit :lipsrsealed:
Offline Adam
« Reply #2 on: 11 August 2010, 15:33 »
Agreed! Nor down the wing and into the door.
Best off putting it though the fuse box. Remove the scuttle pannel on the OS and put it down though the black box.
Down Hill From Here.
Offline Hulmie
« Reply #3 on: 11 August 2010, 15:36 »
was looking at the bonnet cable grommit but thought it wasnt a good idea. i dont have a black box but i do have a white box, take it theres a grommit in there i can push it through. Where abouts would it come through on the inside of the car?
Offline Adam
« Reply #4 on: 11 August 2010, 15:49 »
That's the one. It comes out behind the fuse box.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #5 on: 11 August 2010, 15:54 »
i did mine though the bonnet gromit, no problems here.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 11 August 2010, 17:05 »
fuse box for me, dunno where it comes out, it was just there when I looked under the dash lol
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #7 on: 12 August 2010, 08:51 »
took mine in through the top fuse box theres a spare grommet under the main one iirc i went through that and pushed down and the vac line comes out behind the fuse box on the drivers side end panel  :wink: just a case of feeding your pipe up to the vent then paul  :wink:
2000 Mkiv GTi 1.8T AGU
Offline Hulmie
« Reply #8 on: 12 August 2010, 09:03 »
Cheers peeps, just have to get me some longer vac pipe.
Offline seanbmx
« Reply #9 on: 06 September 2014, 20:24 »
Ok so I've had a look at the fuse box and how the fudge I am supposed to get the vac pipe thru their??
