Author Topic: Sams Scruffy Mk3!  (Read 203110 times)
Re: Sams Scruffy Mk3!
« Reply #340 on: 16 May 2012, 21:15 »
the bolts are 'BZP' high tensile steel, i was advised that they would be strong enough, opinions welcome though?
They need to be at least 10.8 grade, 12.9 if you can get them, check and see what is stamped on the bolt head.
Offline murraymint
« Reply #341 on: 16 May 2012, 21:15 »
I can see a lot more people doing this from now on! Me included  :cool:
josh
Gavv8
« Reply #342 on: 16 May 2012, 21:22 »
I love this car so much.. :cool:
Offline Seanl
« Reply #343 on: 16 May 2012, 21:23 »
Would be a ball ache removing them every time if you had different offset wheels for winter though!  :grin:
Think the reason this isn't done more often is simply down to the ....simplicity........ of adding spacers on the wheel side. Obviously cant do anything of this sort if you need to adapt the PCD though. Still, good thinking!  :smiley:
« Reply #344 on: 16 May 2012, 21:28 »
The other thing is you putting a lot of stress on the stub axle bolts.
Offline rcsammy
« Reply #345 on: 17 May 2012, 00:01 »
surely its less stress than wheel bolts though as it would get all the same forces except they all have to go through the wheel bolts first
Offline Seanl
« Reply #346 on: 17 May 2012, 07:15 »
Think its probably more actually as the stress point is further in.
« Reply #347 on: 17 May 2012, 08:00 »
Agreed :afro: I still think will spacers are safer  :undecided:
Offline rcsammy
« Reply #348 on: 17 May 2012, 14:22 »
the bolts i have are rated 8.8, any recommendations on where to get better ones? when i was looking for them no where seemed to list the rating
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #349 on: 17 May 2012, 15:01 »
In all seriousness mate, I really wouldn't drive it with those bolts fitted. 8.8 are soft as sh!t!
