Author Topic: advice needed pease  (Read 1951 times)
Offline gophgti
advice needed pease
« on: 02 August 2010, 17:49 »
took my 8v to the garage last week had power stering pump replaced, but the car is running like crap so they had  look and said the maf was broke,
so i dissconnected it and drove it and all was well, so i brought a new maf and fitted it and its still them same, it ticks over like crap the whole car shakes like its about to stall,it stalls every time i reverse, and when pulling off or driving it feels like somthing is pulling the car back like the handbrakes on, its just had a new maf,coolant temp sensor,fuel pump relay fitted, any ideas whats causing this? i tryed my vagcom but its decided to stop working lol
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: advice needed pease
« Reply #1 on: 02 August 2010, 19:52 »
Clean the throttle body, all the vac hoses and try running it with the carbon canister un-plugged, thats the cylindrical thingy bolted to the shocker housing just behind the air box, mine runs like sh!t with it plugged in, runs fine with it un-plugged  :wink:
Offline harlemex
« Reply #2 on: 02 August 2010, 21:34 »
reset the ecu by disconnecting the battery for 15mins. This should do the trick.
Offline gophgti
« Reply #3 on: 03 August 2010, 23:22 »
hey guys i tryed reseting the ecu left the battery off for a good hour or so but she's still the same most of the time the engine hesitates to the point where the cars at a crawl even in 3rd or 4th even with ur foot to the floor?
Offline robz
« Reply #4 on: 04 August 2010, 12:23 »
ya got any air leaks in the vac pipes??
ya say it runs fine when ya unplug your new maf meter??
if so could be dodgy??
Offline gophgti
« Reply #5 on: 04 August 2010, 13:15 »
il double check for vac leaks the maf is brand new unless the wire is dodgy? could it be the lamba sensor?
Offline zdebx
« Reply #6 on: 04 August 2010, 13:47 »
Yeah, could be the lambda sensor.
Also worth replacing the ECU (no 30) and fuel pump relays (no 167). Cheap parts anyway.
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline gophgti
« Reply #7 on: 15 August 2010, 23:35 »
ok guys iv replaced the ecu and fuel pump relays and still no change also cant find any air leaks? wat would u suggest next? could faulty coil pack cause this?
« Last Edit: 15 August 2010, 23:51 by gophgti »
Offline ian24driver
« Reply #8 on: 16 August 2010, 06:26 »
how much did you pay for the power steering pump plus fitting?
Offline gophgti
« Reply #9 on: 16 August 2010, 11:40 »
lol i won the pump off ebay for £7 and fitting was £20 bargin!
