Author Topic: strange drone....  (Read 2354 times)
Offline vdubnut
strange drone....
« on: 27 July 2010, 18:24 »
Getting an odd droning noise coming from the car @ about 60 mph plus....thought was exhaust but had this checked and its fine....wheres next to check....(wondered wheel bearing?) had the rears and the front right done recently but jacked up front left and no wheel wiggle when jacked up?
Any help appriciated!!
Offline local_boy
Re: strange drone....
« Reply #1 on: 27 July 2010, 20:51 »
Check the rears, might need re-adjusting now they have settled
Offline AudiA8Quattro
« Reply #2 on: 27 July 2010, 20:58 »
Does the drone go when you depress the clutch?
Offline Jack3559
« Reply #3 on: 27 July 2010, 21:06 »
As I've discovered, the wheel won't necessarily wiggle if the bearing's shot.
It could be that you have worn hubs... like me!
Check out my video on vimeo to see if the noise is similar.
http://vimeo.com/12837342
Offline vdubnut
« Reply #4 on: 27 July 2010, 21:18 »
AudiA8Quattro : no change when depress clutch....will check the rears again....sounds a little like the vid clip but nowhere near as bad.....upto about 50mph seems pretty quiet?
« Reply #5 on: 27 July 2010, 21:30 »
Wheel bearing
« Reply #6 on: 27 July 2010, 21:47 »
Yep i would say wheel bearing.
Offline Jack3559
« Reply #7 on: 27 July 2010, 21:49 »
+3
Offline vdubnut
« Reply #8 on: 27 July 2010, 21:53 »
was my fear to be honest :( any easy way to find out which though!?
Offline Leon27
« Reply #9 on: 27 July 2010, 22:01 »
Raise car on ramp and drive it up to 60, listen to hub with a long screwdriver.
