Author Topic: strange drone....  (Read 2350 times)
Re: strange drone....
« Reply #10 on: 27 July 2010, 22:02 »
Or get someone else to drive, then lie in the back and listen
Offline vdubnut
« Reply #11 on: 27 July 2010, 22:08 »
cheers all .....off to look for a long scewdriver  :rolleyes:....will update tommorrow
Offline Leon27
« Reply #12 on: 27 July 2010, 22:26 »
Mis read, if its the front wheel bearing then putting it on the ramp and driving it will work using the screw driver if its the rears then you'll need to drive it on the road.
Offline Len
« Reply #13 on: 28 July 2010, 09:06 »
Does it only happen at certain revs? Say around 4000 rpm then fade off again as revs go higher?
www.sas.org.uk
www.the-ace.org.uk
Offline vdubnut
« Reply #14 on: 28 July 2010, 10:30 »
seems to get louder faster i go ....(its on a smoke burner rather than a gti)
Offline robz
« Reply #15 on: 28 July 2010, 10:31 »
sounds like rear wheel bearing!
the way i always test em is get to the loudest speed then almost f1 style swerve from left to right, eg, swerve right, weight is on the left rear, gets louder, thats the one, and vice versa!!
Offline harlemex
« Reply #16 on: 28 July 2010, 11:38 »
+20, definately bearing.
Offline vdubnut
« Reply #17 on: 28 July 2010, 13:20 »
looks like back right wheel bearing jacked up all 4 and that wheel is not wobbling but does make noise when spinning it.. are they easy to adjust or is it just forked?
« Reply #18 on: 28 July 2010, 13:32 »
It is better to replace it if it is making a noise.
Offline vdubnut
« Reply #19 on: 02 August 2010, 20:04 »
cheers everyone for the help :) changed now :) noise gone much relieved!
