Author Topic: I need new hubs...  (Read 1593 times)
Offline Jack3559
I need new hubs...
« on: 27 July 2010, 00:37 »
Anyone know where to get a new hub?
I've called around loads of part guys today and they don't stock them...
1.9TDi wagon...
Or does anyone know if any other hubs will fit?
Offline Len
Re: I need new hubs...
« Reply #1 on: 27 July 2010, 09:01 »
Sure its hubs you need and not bearings?
Try ECP or GSF
www.sas.org.uk
www.the-ace.org.uk
« Reply #2 on: 27 July 2010, 09:13 »
and is it the hub or the entire wheel bearing housing you are after
Offline Jack3559
« Reply #3 on: 27 July 2010, 11:42 »
All of it!
I need new hubs and bearings...
I need the whole of that.
« Reply #4 on: 27 July 2010, 11:44 »
What is wrong with the hubs ?
Offline Jack3559
« Reply #5 on: 27 July 2010, 11:57 »
I'm not really sure...
All I know is that it eats wheel bearings like mad.
I've replaced the NSF wheel bearing 3 times this year - If I'd done it as soon as it needs doing I'd have needed a new one every couple of weeks.
I think my ball joint is out as well, but basically... Under acceleration the car lurches to the right and the NSF wheel has negative camber, which is wearing the tyres out like nobody's business.
Apparently the hub is worn, so that it's not holding the bearing in tight enough.
« Reply #6 on: 27 July 2010, 12:02 »
Not good then, if it has worn they are right and the bearing will not be tight.
« Reply #7 on: 27 July 2010, 13:05 »
righty oh.  I believe TDI has 4 stud yes? if so high spec MK2/3 or any Corrado/passat 4 stud will work, as will one from various SEAT models.  basically most VAGs with 4 stud and 256+ discs. Only exception is some polos have different bearing carriers which arnt suitable.
Offline Len
« Reply #8 on: 27 July 2010, 13:07 »
I would definitely also do the bottom ball joint.
www.sas.org.uk
www.the-ace.org.uk
Offline dontknow17
« Reply #9 on: 27 July 2010, 15:17 »
Im breaking my golf and i have the hubs you need and 2 brand new bearing kits still in the boxes. £20 and theyre yours, if you want to collect them from near southampton!
let me know mate
Elliott
07787447835
Practice Makes Compound Fractures, then Perfect
