Golf mk2
my radiator didnt fit...
Topic: my radiator didnt fit... (Read 1544 times)
rowleyslims
GTI forum regular
hakuna mutata
26 July 2010, 08:55 »
so i bought a new radiator and it didnt fit. it was way to small so i need to make an exchange..
http://www.autopartswarehouse.com/search/?N=0&Nr=AND(wpn_tl_name:Engine+%26+Drivetrain,wpn_cat_name:Radiators%5C%2C+Cooling+Systems+%26+Components,wpn_scat_name:Radiators
what radiator should i get that will fit my car. i thought all the radiators would be the same since they are all marked for a 1992 golf gti (gl) 8v. i was obviously wrong. what one do i need?
img src= "
http://www.pro-motor.be/images/passe/soignies01.jpg
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: my radiator didnt fit...
26 July 2010, 09:39 »
3 common sizes available, which one did you get?
1.6 8v & 16v - 430mm
1.8 8v - 525mm
diesel & a/c models - 675mm
russ-vdub
Once a Dub, Always a Dub
28 July 2010, 11:47 »
Is it ok to fit a diesel on to an 89 8v providing you change the pipes or will it knacker the water pump?
CHECK OUT MY DNB, DUBSTEP & ELECTRO MIXES HERE
My DJ Fanboi Page
rubjonny
10k hero
28 July 2010, 13:20 »
no be fine, just as you say gotta get the pipes to fit. wont offer you anything though really the std rad is more than good enough
Cory
Here all the time
29 July 2010, 11:12 »
does anyone know the quantity of coolant a 1.6 radiator holds? am i right in thinking its 5 quarts?
and also whats the coolent to water mix?
many thanls
cory
rubjonny
10k hero
29 July 2010, 13:46 »
around 6litres, but unless you take out the stat and fully drain the matrix somehow you'll never get all the old coolant out. 50/50 mix works for me
Golf mk2
