Author Topic: 1.8t conversion gearbox  (Read 1743 times)
Offline Dan_GTi8v
« on: 25 July 2010, 14:41 »
been thinking over my shopping list for the conversion, and seen I have 02a gearbox from a 16v, and abf flywheel in my list.
As the abf flywheel is out of a 16v, and im getting a 16v box, I dont need to get the flywheel do I? Or is it a good idea to get a new one
Also, will the 16v clutch be able to handle 200+ bhp or should I get the vr6 clutch?
Re: 1.8t conversion gearbox
« Reply #1 on: 26 July 2010, 09:16 »
you need an 02a 4 pot flywheel from a G60, Corrado, Passat or MK3 ABF or TDI to match that box. some of the Passat flywheels are smaller so make sure its a 228mm type.  As for clutch, VR6 one would be a good idea if you're planning on upping the power
Offline Dan_GTi8v
« Reply #2 on: 26 July 2010, 12:42 »
I guessed I'd need a the vr clutch but thought I'd ask anyway :P
The 02a box I'm getting will be from a 16v mk3 ABF, gearbox code CDA, so this should already come with the lighter flywheel, am I right?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 26 July 2010, 15:33 »
may or may not come with flywheel....
Sachs vr clutch is a must tbh. dont be cheap and get a LUK!
Offline Dan_GTi8v
« Reply #4 on: 26 July 2010, 20:11 »
whats the difference?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #5 on: 27 July 2010, 08:04 »
Just different brand names. LUK is the cheaper brand, Sachs is meant to be the good quality brand and from the feedback people have given that have used the two different clutches on the g60/vr6 flywheel/clutch setup on mk4 1.8t's, Sachs appears to be better. Just for the price difference you might as well go for the "better" brand.
« Reply #6 on: 27 July 2010, 09:22 »
LUK are a good make but I have heard of them failing early, whereas std sachs never. Some people have had no issues at all with LUK units though, so it could be down to isolated failures.  LUK parts are used in OEM clutch kits as well, though iirc the VAG kits have LUK bits and sachs bits, the bits in the kits aren't always from the same manufacturer. for some reason people have had issues with the 'sporting' sachs units?
But this is only 2nd hand information, I cant really offer any personal experience with the LUK units as I've never fitted one.  I've only ever used sachs kits in the engine builds I have put together and touch wood, no failures yet :)
« Last Edit: 27 July 2010, 09:25 by rubjonny »
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 27 July 2010, 09:35 »
I've done about 10k of hard driving on a vr6 LUK clutch and no issues yet. That's with 260lbft of torque and pulling along a heavy mk4 estate. Now that i've said that it'll start slipping today :grin:
« Reply #8 on: 27 July 2010, 09:37 »
Have used LUK all ok in the past.
