Author Topic: 1.8t conversion - exhaust system question  (Read 826 times)
Offline Dan_GTi8v
« on: 22 July 2010, 23:34 »
Just got a jetex cat back, and I know i'll be needing the 1.8t downpipe (will probably get a sports one)
question is, will the 1.8t cat fit unmodded onto an 8v GTi?
Re: 1.8t conversion - exhaust system question
« Reply #1 on: 22 July 2010, 23:35 »
I think you need to run a 16v system.
LL will tell you 100%
Offline Dan_GTi8v
« Reply #2 on: 23 July 2010, 06:58 »
I thought the only difference was the bore size? The jetex I have is suitable for both 8v and 16v so I guess you need some kind of reducer pipe for the 8v as I havn't fitted it yet
What would happen if I ran the 1.8t cat while still using the AGG 8v engine? Would it work? Just trying to get as much done as I can before the engine work begins
« Reply #3 on: 23 July 2010, 08:39 »
Cat will not fit, 99% it is a different layout.
