Author Topic: my mk2 abf track car  (Read 70181 times)
Offline Diamond Hell
  • Opinions я Us
Re: my new track sl@g
« Reply #70 on: 29 August 2010, 11:21 »
What camber do you have on the front?
Dialing some more in might help the understeer issue, as it should see  more grip on the front, unless you already have some on there.  I run about -2.5 degrees on the front of the Syncro.
You could also look at fitting a stiffer rear anti-roll bar, but get the front end set up right first.  VW liked dialing plenty of understeer into their cars in the 80's and 90's as standard.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #71 on: 29 August 2010, 13:05 »
i really not sure tbh dh all i done was put as much camber is a could on it with the mk3 set up from what i have read u dont get as much with this setup
the front tyres have worn equally so im guessing its not to far off but im not sure
after we had softend the front up had no were near as much understeer unless u gave it large out of the tight bends then it would start to a little bit
its really the rear end feels very loose i guess a bit all over the show i sopose could be a whole number of things axle bushes/suspension set up dont think bearings are a issue as all new
Offline gti3_elston
  • the car in front is a vdub
« Reply #72 on: 31 August 2010, 21:57 »
nice work mate, well done!  :cool:
.this isnt just a golf, this is a VW golf!
  • Opinions я Us
« Reply #73 on: 31 August 2010, 22:53 »
Get some new OEM bushes in the back end and get the front properly set up - should make a world of difference.  :cool:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #74 on: 23 September 2010, 16:52 »
managed to find a omp rollcage for 200 notes brand new never fitted  :smiley:
  • Opinions я Us
« Reply #75 on: 23 September 2010, 18:03 »
Lucky bast.
Now get some appropriately-sized CDS stitched in for harness bars.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #76 on: 23 September 2010, 18:04 »
oh yes take it i will need same size as roll cage ?
Offline JonLeeper
« Reply #77 on: 23 September 2010, 18:05 »
Barsteward!  Why di i never find these things!  :angry:
  • Opinions я Us
« Reply #78 on: 23 September 2010, 18:05 »
Let me have a dig - I think I have specs somewhere....
Offline leeroy20vt
  • h reg mk2 gti
« Reply #79 on: 23 September 2010, 18:05 »
cheers m8y  :smiley:
