Author Topic: Idle screw o-ring part number?  (Read 3190 times)
Offline Gambit
Re: Idle screw o-ring part number?
« Reply #10 on: 24 January 2005, 11:03 »
yeah there should only be one o-ring but i found when i tried putting on the new o-ring that it wasnt tight enough so i squeezed 2 into the groove
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #11 on: 24 January 2005, 19:07 »
Thanks mate, the current o ring is really hard (like solid plastic) I have yet not found a suitable or ring, Halfrauds don't do them (well the one by me does not)
Did you have to cut yours off with a scalple?
I guess as long as the new o ring is just bigger then the diameter of the screw then it will do it's job?
Offline Gambit
« Reply #12 on: 25 January 2005, 09:32 »
they go hard after time. cant remember how i get mine of but im near enough sure i cut it off somehow
the ones i got werent a perfect fit either. hence why i squeezed 2 on
Offline Deefadog
« Reply #13 on: 25 January 2005, 18:25 »
Cheers, I'll get cutting away :)
(I may hav asked this beore, s forgive me if ihave but) Just a thought, if air is leaking here would this lower my mpg?
Offline Gambit
« Reply #14 on: 26 January 2005, 12:28 »
shouldnt lower the mpg that much. main reason for getting a tight fit is to stop the screw untwisting under engine vibration and slowly raising the idle speed
Offline Deefadog
« Reply #15 on: 26 January 2005, 13:57 »
O well, I was hoping it would be that :(
