Author Topic: Idle screw o-ring part number?  (Read 3199 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 06 January 2005, 14:52 »
Happy new year to you all!
I am after an idel screw o-ring, but the dealers can't seem to find it on their system (nothing new there then)
Could some who has got the ETKA software look it up for me please.
Thanks again
Offline Gambit
Re: Idle screw o-ring part number?
« Reply #1 on: 06 January 2005, 16:48 »
you cant get the o-ring from VAG. u cant even buy the screw complete with o-ring. u have to buy a new throttle body!!
go to halfrauds and pick up a set of multi-size o-rings and you'll find one that fits in it.
VeeDubGTI16v
« Reply #2 on: 06 January 2005, 16:52 »
hmm reminds me of the new distributer o-ring i needed, but because its a 1/2 size you cant get them off the shelf and have to buy a new distributer :angry:
Offline Deefadog
« Reply #3 on: 06 January 2005, 18:41 »
Cheers, that explains it then :)
Offline Deefadog
« Reply #4 on: 07 January 2005, 13:28 »
Just to double check (my mind has gone blank after xmas) on the idle screw, does the screw allow air from outside the screw to the inside or should no air get in from the outside?
Offline Gambit
« Reply #5 on: 07 January 2005, 17:15 »
you want it to be airtight
Offline Deefadog
« Reply #6 on: 08 January 2005, 08:49 »
Cheers mate, so no air from the outside get's in passed the screw then yes? It's all done inside?
Offline Gambit
« Reply #7 on: 08 January 2005, 16:27 »
yes. give the o-rings a little swab of grease also for a tighter seal
Offline Deefadog
« Reply #8 on: 08 January 2005, 17:45 »
Cheers mate!  When you said "o-rings " Are there more than one? as i only have one on there at the moment!
Offline Deefadog
« Reply #9 on: 22 January 2005, 14:59 »
Am I missing a 'o' ring?
here is? pic of mine -
Should there be just one o ring in the middle of it?
Thanks
