Author Topic: will a mk3 8v master cylinder fit a mk2 1.3  (Read 2189 times)
Offline leeroy20vt
  • h reg mk2 gti
« on: 18 July 2010, 22:02 »
as above doin a wide track conversion will it fit or will the original be ok
cheers
« Last Edit: 18 July 2010, 22:46 by leeroy20vt »
Offline fishnchipsx2
Re: will a mk3 8v master cylinder fit a mk2 1.3
« Reply #1 on: 18 July 2010, 23:20 »
Check the mounting holes... it may fit, but rotated at an angle of about 30 degrees, meaning that the reservoir will be on the piss - not ideal for an MOT!
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 19 July 2010, 08:36 »
cheers fella
« Reply #3 on: 19 July 2010, 11:47 »
should fit straight on, they use same 22mm MC as late MK2 16v & G60
Offline leeroy20vt
  • h reg mk2 gti
« Reply #4 on: 19 July 2010, 11:50 »
goin back to ur pms tho wont be much cop for the 288 mk3 brakes tho will it ?
and out of all the stuff i got i havent got a mk2 1.8 servo typical a
« Reply #5 on: 19 July 2010, 11:54 »
yeah it'll be fine on 288s, same as whats fitted to the MK3 with 288sas standard ;)
its the servo you need to change, want a 9" servo from mk2 1.8, or corrado/passat. unfortunatly mk3 one is no use as totally wrong fitment. needs to be from passat pre-97, b3 or b4 shape. abs servo will work too, it'll just have an extra switch in the side of it which you leave in place but unplugged
Offline leeroy20vt
  • h reg mk2 gti
« Reply #6 on: 19 July 2010, 11:58 »
ar just relised i missed part of the question lol should of put will it fit on a 1.3 servo  :embarassed:
o well thats goin to hold me up till i find one as its much easier to fit without engine in  :cry: :cry:
cheers rj
« Reply #7 on: 19 July 2010, 12:04 »
yeah it'll fit, but as i say you'll want to bin that servo and get a 9" one :)
you can fit one with engien fitted, i have done it on an 8v and that was with the inlet manifold on the car as well! theres literally a MK2 servo shaped gap  :grin:
be fine with a 16v engine fitted without the inlet, should be tons o room. i didn't even disconnect the master cylinder to do it, i just carefully pushed it out of the way.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #8 on: 19 July 2010, 12:05 »
ok  :cool: :cool: mayby engine will be in today then  :smiley:
