Author Topic: ABF 2.0 woohoo!  (Read 29775 times)
Offline Gti-Grimes
  • 180 ponies :D
Re: ABF 2.0 woohoo!
« Reply #60 on: 28 July 2010, 23:47 »
Heh, a Focus ST you say?
You've not been using the seat of your pants in the real world, against an ST have you?
Have you done a compression test on the motor - if it's burning oil it sounds like it's had most of the mechanical goodness extracted from it....
Sorry mate, what do you mean by that second sentence? ..... Not done a compression test as the car has other issues, so swapping to the other car as the bodywork is not far off mint. Engine and car will be for sale shortly for anyone who is interested. Think the engine has had a hard life previous to me having it. Is puttin out a confirmed 178bhp, so is fairly nimple for a mk2 golf. Few other cars under the belt on a nice day, not the place to discuss such things though.
Mk2 Golf Gti 2l 16v
Offline Diamond Hell
  • Opinions я Us
Re: ABF 2.0 woohoo!
« Reply #61 on: 29 July 2010, 14:35 »
Are you ever going to stop going on about that?  :tongue:
Yes, when Andywash is no longer mentioned.
Interesting that a seat ibiza with an ABF unit isn't as quick. The ibiza is effectively a polo, so maybe putting an ABF in a golf 2 makes it faster?
Yes, given that most of the Golfs in question have been stripped out, maybe had a tubular exhaust manifold put on them and aren't running a cat.  Those minor mods *might* make them faster than an Aybeefa. Parkers state the weight of an Aybeefa at 1100kg.  Even my Syncro's under that and odds on that's a dry weight, too.
So, remove 100kg, add 10-20bhp..... will it be faster?  You tell me.
Offline AudiA8Quattro
Re: ABF 2.0 woohoo!
« Reply #62 on: 29 July 2010, 21:13 »
I must admit that I would be surprised if a golf 2 weighed less than an Ibiza.
The st argument was about a golf 2 complete with trim with a standard abf lump.
Would that be faster than an Ibiza fitted with an abf.
Probably not.
Offline emery1990
Re: ABF 2.0 woohoo!
« Reply #63 on: 29 July 2010, 21:53 »
whats the 0-60 of an abf ibiza, a 1.8 16v golf with run in engine done it in 7 secs on that top gear video.
I rekon it would be faster, no cat and probally a little bit lighter.
7.9 secondsfor a seat ibiza abf
« Last Edit: 29 July 2010, 21:56 by emery1990 »
Re: ABF 2.0 woohoo!
« Reply #64 on: 29 July 2010, 22:05 »
Cupra 16v book time is 7.8 seconds, book time on a mk2 16v is about 8 seconds. It's hard to find any decent info on mk2s as they are so old.
After doing some searching, the curb weight of a mk2 16v is about 1100 kg, the same as an early Ibiza.
This may not be correct, I will have to check mr.Haynes.
  • Opinions я Us
Re: ABF 2.0 woohoo!
« Reply #65 on: 29 July 2010, 22:42 »
Check a weighbridge instead - it's actually worth something.
Re: ABF 2.0 woohoo!
« Reply #66 on: 29 July 2010, 22:53 »
Does an Ibiza cupra 16v weigh more than a mk2 golf 16v, yes or no?
Offline The Mighty Elvi
  • I'm better than you today.
Re: ABF 2.0 woohoo!
« Reply #67 on: 29 July 2010, 22:56 »
1990 Volkswagen Golf GTi 16v    See all Volkswagen models
Wheelbase    2475 mm    97.4 in
Track    front    1425 mm    56.1 in
rear           1420 mm    55.9 in
Length    3985 mm    156.9 in
Width    1680 mm    66.1 in
Height    1395 mm    54.9 in
Length:wheelbase ratio    1.61
Ground clearance    105 mm    4.1 in
Kerb weight            960 kg      2116 lb
Weight distribution
(Front)
Fuel capacity    55 litres    12.1 UK Gal    14.5 US Gal
http://www.carfolio.com/specifications/models/car/?car=101530
Re: ABF 2.0 woohoo!
« Reply #68 on: 29 July 2010, 22:59 »
They dont have an early Ibiza 16, only Toledo
http://www.carfolio.com/specifications/models/?man=5761
  • Opinions я Us
Re: ABF 2.0 woohoo!
« Reply #69 on: 29 July 2010, 23:08 »
 :rolleyes:
I have neither a weighbridge, a Seat Ibiza or a Golf2 GTI 16V in my front room and I suspect you don't either.
I'm sure your buddy Mark will be along to gee this up shortly.
