Author Topic: gearbox woes!! help needed asap  (Read 2763 times)
Offline pd3k
« on: 17 July 2010, 14:08 »
first of all hey everyone, new to the forum, defintly NOT new to dubs tho lol
anyway, my mk3 gti 8v is very sick!
when idling the gearbox/clutch makes like a cah cah cah like sound, like somethin is grinding (if that makes sense)
struggles to go into most gears, some times it does and somethimes it just does not at all
pops out of 3rd
makes a whine at speed
clutch slips
gets stuck in gear sometimes
makes some interesting noises in reverse
and the last one that i can think of, when you put it into 5th it is like it is in neutral
omg so much!!
also may or may not be related, but every now and then the steering goes really heavy when turning a corner, diff??
ta, sam
Offline justalex81
Re: gearbox woes!! help needed asap
« Reply #1 on: 17 July 2010, 14:32 »
google scrap yards near you.
take it there.
leave it there.
buy a 16v.
Offline pd3k
« Reply #2 on: 17 July 2010, 14:45 »
lol, no! i love my gti, it's mint apart from this, and it does have 16v brakes lol, maybe a 16v eninge one day, but for now, i really need to know what to do, new box?!! i hope not,
Offline justalex81
« Reply #3 on: 17 July 2010, 14:51 »
new box definately mate.
« Reply #4 on: 17 July 2010, 14:53 »
take it there.
leave it there.
buy a 16v.
What a helpfull post
Offline pd3k
« Reply #5 on: 17 July 2010, 14:54 »
yeah i thought a new box would be the way.... ah well, any tips on removal and refitting??
Offline pd3k
« Reply #6 on: 17 July 2010, 15:31 »
and wgat one do i need??  :laugh:
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #7 on: 17 July 2010, 16:24 »
If yr pretty competent, mechanics wise, and you got a mate that will help its reasonably straight forward, although very awkward!!
Any 020 box will fit, although the ratios are different on certain ones I believe. Best off trying to source one from an 8v gti really, theres a couple on the bay at the mo.
Starter motor off, clutch cable off, gear linkage off, bottom rear engine mount off, both drive shafts off, a handful of bolts holding the gearbox to the engine out, a bit of jiggery pokery and its out, reverse to put back in  :shocked:
You will need a special splined tool to remove the driveshafts, everything else is pretty standard tooling.
A garage will probably charge you around £150-£200 to swap it over
Offline pd3k
« Reply #8 on: 17 July 2010, 23:24 »
what splined tool would that be??
would a gearbox from a P reg, 1997, mk3 golf 1.9 TURBO DIESEL fit??
thanks for help! sam
« Reply #9 on: 17 July 2010, 23:29 »
Nope wrong ratios
