Author Topic: GSF crank sensors....anyone any bother? and AFM  (Read 4912 times)
Offline 95gti8v
« on: 16 July 2010, 20:00 »
I had the all too common problem in December of stalling. After a new ECU and Fuel Pump relay replaced the crank sensor and that sorted it. I used a GSF one that was £40 odd as genuine was £180!! That sorted it out and been spot on since.
Yesterday it stalled again, usual symptom oil light loss power. Went to a mate to plug into computor and found out AFM was knackered, replaced that and car going great now as could be a bit lumpy before. Also found a loose spark plug that was actually rotating along with the lead as engine running. Would either of these cause the stalling???
The computor showed an intermitant crank sensor fault, but when I replaced it in December I didn't get fault reset so we didn't know if it was still from then or a new fault. He reset it so if it happens again we'll know new fault. I took it on a 30min drive today at 60mph and it was fine, stopped for fuel and drove another 15mins home.
Could the GSF sensor be crap and would I be as well getting a genuine one? Heading off on hols next week and have to do about 500miles with Mrs and baby so don't want be worrying.
Cheers dudes
Offline javalin
Re: GSF crank sensors....anyone any bother? and AFM
« Reply #1 on: 17 July 2010, 06:55 »
I've done exactly the same - i.e. VW wanted best part of £200 notes - so mines is a GSF.  Very fine so far.  I suspect the test is when the car is hot to get an o'scope on it and see what signal its putting out when the engine is running.  Would also check the wiring - i.e. all the way back to the ECU and the +5v or +12v feed and of course the grounds.
Possibly worth replacing the ECU relay (no.30) cause I would guess (don't know for sure) that relay powers the ECU and related sensors.
AA/RAC cover!
Good luck,
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline 95gti8v
« Reply #2 on: 17 July 2010, 10:30 »
Cheers dude, already replaced ECU relay when did sensor!
Been driving old VWs last 14years and this first time I'm dubious as to whether my car'll do the journey  :embarassed:
Offline 95gti8v
« Reply #3 on: 26 July 2010, 14:59 »
Just did a 500 mile round trip, 44mpg and not a bit of bother, going better than ever has  :cool:
