Author Topic: Bluetooth in MY11 GTI Works with IPhone !  (Read 23446 times)
Offline harvey183
Re: Bluetooth in MY11 GTI Works with IPhone !
« Reply #40 on: 06 August 2010, 18:53 »
Cool! I'm a bit unsure of what wiring needs doing as i think you were talking about to different ones, is all the wiring that needs to be done at the box under the seat?
Offline isse
  • Golf R
« Reply #41 on: 06 August 2010, 20:21 »
It connects the box under the seat and the RNS/RCD unit, so my guess is that it´s a bit of a pain to add an extra wire to the factory cableset, so instead install the new cable kit thats has them all.
/I
« Last Edit: 06 August 2010, 20:32 by isse »
Offline harvey183
« Reply #42 on: 06 August 2010, 20:24 »
Is the new cable kit contained under the seat or does it run back to the rns unit? I take it by installing this I will get sound out of all speakers?
Offline SteveP
« Reply #43 on: 06 August 2010, 20:40 »
Needs to run from the RNS to the bluetooth module.
Offline harvey183
« Reply #44 on: 06 August 2010, 20:45 »
Sorry to be a pain guys! but just so I get this right I need to get the new module 7P6 and then the new wiring kit and run that from the rns unit to the new module under the seat and then hey presto? obv the wiring kit already installed at factory dosen't have enough or the right wires for the new module?
Offline SteveP
« Reply #45 on: 06 August 2010, 20:55 »
^^^ Yes, but you can't just buy the extra wiring loom it needs to be made  :smiley:
Offline harvey183
« Reply #46 on: 06 August 2010, 20:59 »
Cool, I'm with you now! thanks for all your help and being patient! :smiley:
Offline isse
  • Golf R
« Reply #47 on: 13 August 2010, 07:54 »
How did you guys route the cables ?
Im doing a fresh install and will be placing the BT kit under the passanger seat as orginal.
Im planing on routing the cables down from the center console alongside the center console behind the panel to the seat and then out under the seat.
However any tips are appreciated :-)
/I
Offline isse
  • Golf R
« Reply #48 on: 14 August 2010, 17:43 »
Hi guys,
I have just connected the 9W7 unit to my car and done a little testing.
First i connected the mic wrong and got a fault code for that, but that was solved and cleared.
I enabled Telephone on the CAN bus and then everything was fine, i allready had voice-control enabled since i had it as standard on my RNS510.
Now i have 2 issued left and i was hoping someone has some ideas.
1. When i use voice control (press the voice control button on the steering wheel)  i only get to the phone meny, and i can only do phone stuff with voice control. Before i got the the RNS main menu and could choose radio, navigation etc.
2. Everythign works with the 9w7, mic, mdf, a2dp, but in Vagcom there is one error code i cant get rid of on the phone module:
Address 77: Telephone       Labels: None
Control Module Part Number: 7P6 035 730 C    HW: 7P6 035 730 C
Component and/or Version: TELEFON       H05 0440
           Software Coding: 0A00000000010100
            Work Shop Code: WSC 00000 000 00000
              ASAM Dataset: UHVNA A01007 (VW36)
                      VCID: 3245CBE9D447
1 Fault Found:
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 1746 km
                    Date: 2004.14.06
                    Time: 16:42:13
What can this be and how do i fix it ? :-(
Thanks
« Last Edit: 14 August 2010, 17:59 by isse »
Offline Beardo
« Reply #49 on: 14 August 2010, 18:35 »
Did you get the wiring loom from SteveP then Isse?
I asked this lot if they'd sell the parts minus the bluetooth module - they wanted £65!
http://www.uvworldwide.co.uk/vw-golf-skoda-seat-passat-mfd2-rns-510-bluetooth-kit-ver-e-p-1732.html
