Author Topic: Bluetooth in MY11 GTI Works with IPhone !  (Read 23448 times)
Offline isse
  • Golf R
Re: Bluetooth in MY11 GTI Works with IPhone !
« Reply #50 on: 14 August 2010, 19:44 »
No i got the loom from the polish guy, Car-systems.
The loom should be the new one with A2DP etc, for the 9w7.
/I
Offline SteveP
« Reply #51 on: 14 August 2010, 20:35 »
Did you get the wiring loom from SteveP then Isse?
I asked this lot if they'd sell the parts minus the bluetooth module - they wanted £65!
http://www.uvworldwide.co.uk/vw-golf-skoda-seat-passat-mfd2-rns-510-bluetooth-kit-ver-e-p-1732.html
That's about right TBH, I will PM you a price for what I can do it now.
Offline SteveP
« Reply #52 on: 14 August 2010, 20:36 »
Hi guys,
I have just connected the 9W7 unit to my car and done a little testing.
First i connected the mic wrong and got a fault code for that, but that was solved and cleared.
I enabled Telephone on the CAN bus and then everything was fine, i allready had voice-control enabled since i had it as standard on my RNS510.
Now i have 2 issued left and i was hoping someone has some ideas.
1. When i use voice control (press the voice control button on the steering wheel)  i only get to the phone meny, and i can only do phone stuff with voice control. Before i got the the RNS main menu and could choose radio, navigation etc.
2. Everythign works with the 9w7, mic, mdf, a2dp, but in Vagcom there is one error code i cant get rid of on the phone module:
Address 77: Telephone       Labels: None
Control Module Part Number: 7P6 035 730 C    HW: 7P6 035 730 C
Component and/or Version: TELEFON       H05 0440
           Software Coding: 0A00000000010100
            Work Shop Code: WSC 00000 000 00000
              ASAM Dataset: UHVNA A01007 (VW36)
                      VCID: 3245CBE9D447
1 Fault Found:
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 1746 km
                    Date: 2004.14.06
                    Time: 16:42:13
What can this be and how do i fix it ? :-(
Thanks
Did your car originally have the OEM bluetooth?
If not then it may be looking for the overhead controls that are factory fitted with the bluetooth kit.
Offline isse
  • Golf R
« Reply #53 on: 14 August 2010, 20:45 »
Hi Steve, no my car did not have a any OEM, so i dont have the overhead buttons etc.
Are there normaly cables from the BT kit to the overhad stuff?
Becouse i seem to have a few cables les then people who have factory mounted kits.
Do you also know how to use voice control for the Navi and radio when you have a Phone system installed ?
I only seem to be able to Voice control the phone, but before i installed it i could voice control everything..
/I
« Last Edit: 14 August 2010, 23:00 by isse »
Offline SteveP
« Reply #54 on: 14 August 2010, 21:05 »
Yes there are additional connections in the loom for the control panel in the overhead area.
Offline Beardo
« Reply #55 on: 14 August 2010, 22:26 »
I knew I should of said £40:-)
Offline irknight
« Reply #56 on: 09 June 2011, 10:48 »
Hi Sorry to rehash this old post but i've had a good read through it and just want to clarify a few things.
I have the premium bluetooth installed which I believe uses the RSAP protocol - This isn't so good for me as I have an iPhone and being a bit of an apple fan, changing my phone is not an option.
From reading this post it sounds like I need to do the following :
1. Buy the new module (7P6) which is compatible with iPhones
2. Doctor the wiring loom supplied with the new module to enable audio to left speakers.
3. Rewire the new loom from the bluetooth mudule under the seat to the RNS head unit in central console.
Does that sound about right?
If the above is correct - if I choose to just swap out the module, will I be able to make calls, use the mic, scroll the address and hear the person on the other end of the line (albeit just through the left side)?
Mk6 GTI |5 Door | Black | DSG| 18" Monzas | Vienna Leather | ACC | Winter Pack | Luxury Pack | Cruise Crontrol | Front and Rear Parking Sensors | RNS 510 | Dynaudio | 6 Disc Autochanger | VW Premium Bluetooth| Sunroof | LED Xenons
Offline irknight
« Reply #57 on: 14 June 2011, 13:31 »
Hi Guy's, been trying to dig around a bit for what i need to do here so that I can use my iPhone in car.
I've found this on ebay :
http://cgi.ebay.co.uk/VW-UHV-Premium-Bluetooth-5N0035730D-RNS-510-iPhone-A2DP-/190521956157?pt=Freisprechanlagen&hash=item2c5bfe573d&clk_rvr_id=240331014777
Should I just be able to swap out the currently bluetooth module that is under my drivers seat and add the new one - no leads to change etc .....
Thanks in advance for the help.
Offline Buck
  • Das Auto
« Reply #58 on: 14 June 2011, 22:53 »
I bought this unit earlier this year and installed in in my GTD. IT should be a literal swap out - no additional leads.
When you install it should offer you a pairing code - rather than it being '1234' like some bluetooth systems it will be something like '1111222233334444' a bit longer but that's normal!
Mine works very well with an occasional slow synch of the pre-programmed fast dials on my RNS510 but other than that it's spot on!
Offline irknight
« Reply #59 on: 15 June 2011, 09:14 »
Thanks Buck - appreciate the help.  Looks like that will be my next purchase then.
Anyone want to buy an Rsap premium bluetooth module from me ? :-)
