Author Topic: Bluetooth in MY11 GTI Works with IPhone !  (Read 23458 times)
Offline mortygt140
Re: Bluetooth in MY11 GTI Works with IPhone !
« Reply #20 on: 23 July 2010, 06:21 »
Steve the loom I sold Mike is the new voice control looms and should be fine but if they are wrong I would like to know so I can correct them before they go out??
Darren
Offline SteveP
« Reply #21 on: 23 July 2010, 07:46 »
Hi Darren,
On my loom I had left channels missing, this is in the green telephone plug on the RNS end: -
Headunit Pin 5 - Bluetooth Pin 5
Headunit Pin 11 - Bluetooth Pin 4
Hope that helps
« Last Edit: 23 July 2010, 13:53 by SteveP »
Offline mike.
« Reply #22 on: 23 July 2010, 13:51 »
Had a quick look at this today..
On the Quadlock end, MIC IN and MIC OUT are looped together, this is then connected to the actual MIC and the MIC IN on the Bluetooth Module.
So the MIC is connected to two inputs at the same time without using the loop through and is also connected to the MIC OUT on the RNS.
The left channels are also missing for Bluetooth Audio
I think these are the connections required for the left channel which is slightly different from Steve above
« Last Edit: 23 July 2010, 13:53 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline SteveP
« Reply #23 on: 23 July 2010, 13:54 »
^^^ Mike, my original post was wrong, 5-5 is the correct link  :smiley:
Offline mike.
« Reply #24 on: 23 July 2010, 14:14 »
No problem Steve.
I have now rewired the MIC,
MIC connected to MIC IN on Headunit
MIC OUT on Headunit connected to MIC IN on Bluetooth Module
Wired the left speakers in as above.
All is now working, all faults are clear and Bluetooth Streaming is now working    :smiley:
Offline daparson
« Reply #25 on: 23 July 2010, 16:36 »
Just spoke to the stealer and they want £318 +VAT for the unit. Apparently its special order from Germany ..
Anyone had any joy in getting any financial "help" in swapping the unit out for the latest one ..?
Dave
Its arrived!!: Candy White GTI , cloth interior, winter pack, luxury pack, park assist, RCD510 ...
Offline mortygt140
« Reply #26 on: 23 July 2010, 18:43 »
Cheers Steve and Mike for the input Ill make sure they are swapped if I send any more out.
Darren
Offline Beardo
« Reply #27 on: 26 July 2010, 16:18 »
With help from Mike (Cheers Mike!) i've now also installed the 9W7 in my GTI which had a rSAP premium unit in as standard.
I too have the bluetooth streaming only coming through on one side which seems fixable now but i also have slightly distorted/garbled audio coming from the unit. Anyone getting similar?
It all works but the quality is very poor and not quite how its supposed to be i'm sure!
Offline mike.
« Reply #28 on: 26 July 2010, 16:31 »
I know my streaming sounded distorted before I fixed the cable.
What head unit do you have? I take it yours is under the drivers seat which may make it a bit more awkward to check the cable..  :sad:
I have just checked the ring tones on mine and they seem clear.
I have noticed that I have to turn the phone volume up to near max to hear the other person but it is not distorted.
I have gone into the adaption using VCDS to modify the values but it crashes each time.
Maybe the module is that new the coding hasn't been worked out yet.
Maybe you could try the factory reset on the unit to see if that helps.
Steve has done the same as you, I think, changing the Rsap Module for the 9W7.
Offline isse
  • Golf R
« Reply #29 on: 29 July 2010, 14:03 »
So what is the best bet if you are going to install this module from scratch(not replacing a previus), do i use the plug and play cable that you get with the module (from e-bay) or do you dismount that and connect the cables to the original connector ?
Thanks!
/I
« Last Edit: 29 July 2010, 16:42 by isse »
