Author Topic: MFA  (Read 1346 times)
Judderi
MFA
« on: 04 January 2005, 14:05 »
Since i have had the battery disconnected etc etc while fixing a starting problem my mfa has now got a number 4 displayed. When i press the buttom or move the selector it just stays. It used to work fine. I have not yet tried pulling the fuse because i dont know which one it is. Any ideas anyone?
Offline druid
Re: MFA
« Reply #1 on: 04 January 2005, 16:56 »
Try removing the fuse for it.
i think its fuse 3 but double check.
Leave it out for 10 secs then replace.
should reset the MFA for you.
Offline gibby
Re: MFA
« Reply #2 on: 04 January 2005, 17:21 »
Take the fuse out as you are going to do but here's a little MFA website that you might want to save as a favourite for future reference. http://www.myscirocco.com/scirocco/mfa/engels/mfa_02.html  :smiley:
......now officially dubless.
Re: MFA
« Reply #3 on: 05 January 2005, 12:23 »
On early cars (hazard on dash) the fuse is #3
On late cars (hazard on steering column) fuse is #21
Either way it tells you what the fuses do on the back of the fusebox cover.
Edit: Some people suggest you take the negative lead off the battery which also works :)
« Last Edit: 05 January 2005, 12:25 by rubjonny »
Judderi
Re: MFA
« Reply #4 on: 06 January 2005, 12:38 »
The good old fuse pull solved it. Cheers guys.
