Golf mk2
how to fit a gear gaitor
Topic: how to fit a gear gaitor (Read 1374 times)
mboon
GTI forum regular
13 July 2010, 08:43 »
as above. How do you remove the plastic bit that holds it on
is the gear knob screw fit. Any tips and hints
Part of the GTi 16v Flying Squad and the Special Forces //M Department
dragonfly
Re: how to fit a gear gaitor
13 July 2010, 08:50 »
Yes the gearknob is screw fit. Once removed either slide the gaitor over the shaft or break the plastic collar. You can secure the new gaitor with a small zip tie at the top.
mboon
GTI forum regular
13 July 2010, 15:05 »
Sorted, cheers
russ-vdub
Once a Dub, Always a Dub
14 July 2010, 15:45 »
^^ You need a Haynes
CHECK OUT MY DNB, DUBSTEP & ELECTRO MIXES HERE
My DJ Fanboi Page
Thom89
Forum addict
Looking for an "Icebreaker"
16 July 2010, 13:55 »
To do the job correctly, turn gaiter fully inside out, place over gear lever upside down, fasten cable tie around lever shaft, then pull gaiter down to secure the base, this way the cable tie is fully hidden, and looks OE, as opposed to gash
Thom
Golf mk2
